Looks to a handy item for setting carbs the 'lean drop' method....and multi-mehttp://www.harborfreight.com/lcd-aut...kit-95670.htmlter.
multi-meter......multi-use
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Tags: None -
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather ride -
Hey Moto! Obviously I'm a Fluke man being in the electrical field, but I know many manufacturers have the Tach attachment. My question is: would it show the actual RPM, or half or double, as it attaches to the #1 spark plug wire and counts ignition pulses just like an external tach that you wrap the wire around the plug wire five times.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Hey Moto! Obviously I'm a Fluke man being in the electrical field, but I know many manufacturers have the Tach attachment. My question is: would it show the actual RPM, or half or double, as it attaches to the #1 spark plug wire and counts ignition pulses just like an external tach that you wrap the wire around the plug wire five times.Last edited by WMarshy; 09-02-2014, 10:29 AM.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
I've always been interested in buying an external tachx but wondered if I would always run into this very problem due to our wasted spark system.1979 XS1100F
Depends on the meter setting. Not that it would matter since all you would be looking for in tuning us a drop or rise in RPMs.Nathan
Theodore RooseveltComment
But, I see where it would be handy to read a 50rpm drop when setting idle mixes, which I could see would be a problem hearing a drop that precise. Especially with a non-stock 4 into 1 set-up.Last edited by motoman; 09-02-2014, 11:42 AM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
That was the second asked question on the ST site. I don't really see any way of getting around that though. The STeeds also have the wasted spark, as do most 4cyl. bike applications. Either way, reading in 10rpm incriments a definite plus.
Could just split it by two.......imagine still better than two ears.
Anyway, just thought is was an interesting multi-use unit.
First, let's see if this photo link will work?
Okay, photo works, you can click on it to see it up close. Note that the RPM and cylinder selections are 3, 4, 5, 6, 8 cylinder engines. In the OLD days when cars used cam driven distributors, they only had 1 coil, so with the # of cylinders, the # of spark pulses increased some per RPM. I have found that using the 4 cylinder mode on my old analog dwell/tach/voltmeter, it will read 1/2 the actual engine rpm values.
BTW, this one is using an inductive pickup that clips around the spark plug wire, not the actual primary coil wires. But again because ours is wasted spark, it will still count the same # of pulses just as if it were measuring and counting the primary wire signals.
T.C.T. C. Gresham
