Hey Mike and MATHH,
Okay, here's his front brake picture:
Mathh, looking at the one you posted, the sections where the mounting bolts go thru NARROW both on the caliper body as well as the fork mount.
But his appear to be just cylindrical. I would think that the threads are in the Fork section, and there appears to be some distance/space on the bottom/mating surface/section of the caliper BODY mounting tubes that could be REMOVED to allow the caliper to fit farther down onto the rotor and may not require replacing the rotor!? JAT!!!!
Yeah, those rotors are $$, even floating discs for the OEM are like ~$200.00 or so EACH!!
