New in town
    • 6762
    Originally posted by motoman
    All but empty.......6.5gal. to the top....but you'll wanna immediatley be 'riding' some of that off the top.
    I did that today...topped off so high that it did overflow...it got ridden off right away though...
    • MichaelisEvolving
      • Jul 2014
      • 52
      • Tampa, Fla.
      Anyone tell me what this is on my bike and where the hose coming out is suppose to go?
      79 XS 1100 midnight special frame with an 81 XS 1100 engine or as I like to call it "Mad Max".
        • 9980
        That's your breather for the crank case. It goes to a nipple in the center of the stock air box.
        People who run pod filters rig a smaller filter on there to keep crud from getting into the engine. Still gotta smell the crank case vapors though.
        • MichaelisEvolving
          • Jul 2014
          • 52
          • Tampa, Fla.
          #34
          Cause I noticed that the hose isn't connected to anything and I was wondering how bad that is?
            Just bad in the sense that any blow-by will be syphoned out with increase ease since it's hangin' lower than crankcase........better get that took care of.
            • MichaelisEvolving
              • Jul 2014
              • 52
              • Tampa, Fla.
              #36
              What is blow-by and what do I need to connect it to?
                Combustion blown by rings into crankcase.
                Since you choose to not use the stock airbox, most just use a tiny filter and plug it onto where that hose is hooked now.
                • Eveready1100
                  • 539
                  #38
                  It looks like it's got some serious front forks assembly upgrade, note the dual piston calipers!!
                  Umm......... did anyone else notice it's only got one front disc and caliper??
                  Having a 2 pot caliper isn't as big a step forward after halving the available braking power by deleting a complete assembly
                  • MichaelisEvolving
                    • Jul 2014
                    • 52
                    • Tampa, Fla.
                    #39
                    Where can I get one? Auto zone?
                      #40
                      - - - Anyone tell me what this is on my bike and where the hose coming out is suppose to go?
                      Hi Michael,
                      it's ergonomics are not for this elderly fat man but a nice bike anyway.
                      Like they said, it's the crankcase breather.
                      The EPA Nazis made the mfrs feed it back through the carbs via the airbox but it can happily blow out onto the street just like on my 16H Norton.
                      Or, as the photo shows your drive u-joint is missing it's rubber boot, have it blow oil fumes onto the u-joint to keep the rust off.
                      • Eveready1100
                        • 539
                        #41
                        Michael, as your bike is a work in progress, just wondering if you're going to put the other front disc on with a caliper, or stay as is? Despite the fact that you've removed a bit of weight through stripping the excess bits off, it's still a very heavy bike, and that single disc on the front will struggle to pull the bike up in an emergency, despite the 2 pot caliper.
                        • MichaelisEvolving
                          • Jul 2014
                          • 52
                          • Tampa, Fla.
                          #42
                          I got it with only one on it. Eventually I'll probably put the other one on, I also need to get the back brake working as well. I also need to adjust the valves and it needs the needles in the carbs adjusted. I'm getting there, it's just taking some time. Hahaha.
                          • Eveready1100
                            • 539
                            #43
                            Also, one other thing that Fred pointed out, that you're missing the rubber boot that covers the universal joint. Best to get your hands on one of those and fit it, as the rear driveshaft splines will suffer badly (probably catastrophically) from the ingress of water etc.
                            • MichaelisEvolving
                              • Jul 2014
                              • 52
                              • Tampa, Fla.
                              #44
                              Anyone selling one of these boots?
                                • 9980
                                http://www.ebay.com/sch/sis.html?_nk...1+&_itemId=463
