Can someone IDENTIFY THIS BIKE???????
    In 30 + years a lot of stuff can happen. 750/850 FD swap, rear shock swap, owner swap.........
    I had a 79 fender, seat, and tail light on my 80 for a long time. My front triple tree and forks are from the same SH the FD on The Green Hornet was off of. I have a black highlighted valve cover from that same bike on my SG
    EEHHHHHH.........read my signature.
      • 8064
      Originally posted by Prisoner6
      But it's a little puzzling, Greg ... I've seen '81 Specials with silver FD's, and also some with black FD's ...
      These bikes have been around for 35 years or so. Parts get replaced. Replacing a final drive is easy. The original final drive on a XS1100SH was black.
        Dat's two.......gettin closer..........but Greg already covered that........OOPPss....forgot Prisoner's Midnite........three and counting...
        • Prisoner6
          • Aug 2013
          • 1184
          • Phoenix, AZ
          #49
          Thanks, guys ...
          Marco
          1979 Honda CBX
          2002 Kawasaki ZRX1200R
          WE MISS YOU, DON
            Hint:........only one left...........this side the pond anyways..
              Back to Dylano's pic, Maxim650(XJ), XS11wheels........seat/fender mods........Frankinbike.
                • 3971
                I'll agree with those whom said it was a XS11 Special. Slots on the later wheels were diagonal, and I don't believe that is a reflection I'm seeing, it looks like actual slots. Exhaust looks stock. Ignition cover is unique to the XS11 only due to the vacuum pod. No other XS/XJ had this ignition cover as TomB and Dylano have already pointed out. The footrest hanger is definitely XS11. No doubt in my mind, it's a cosmetically modified XS1100.
                  #53
                  He already said it is abaolutly clear that there are no slots in the real picture
                  • Prisoner6
                    • Aug 2013
                    • 1184
                    • Phoenix, AZ
                    #54
                    Originally posted by Buckmaster79
                    On a 81 the rear drive is black also.
                    You nailed it from the beginning ... Sorry about that, Rod ...
                    Originally posted by motoman
                    Might wanna re-think that Prisoner6..
                    Brant, thank you for pointing out my mistake! Thanks to you and the others here, I learn something new about our bikes nearly every day ...
                    Marco
                    1979 Honda CBX
                    WE MISS YOU, DON
                    • Dylano*
                      • Apr 2014
                      • 202
                      • San Luis Obispo, CA.
                      #55
                      So has it been determined to be an 81 xs11?? Or?
                      I'm confused haha
                      Thank you all for your valuable information thus far though!
                      Have:
                      1994 FZR600
                      1982 XJ1100
                      Had:
                      1996 YZF600R
                      2001 Honda xr125
                      Suzuki race 80
                      Honda PW 50
                      Etc.
                      Getting:
                      1977 DT400
                      • Eveready1100
                        • 539
                        #56
                        Dylano, any chance of you rescanning the original photo in a higher resolution to give a clearer image for us to speculate on?
                        Shouldn't be any reason for a good scan not to be just as clear as an original snapshot.
                        For my guesstimate, I'm saying a lighly customised '79 SF with different rear guard and seat. Shock reflectors could've been just glued on even.
                        Another thing to consider is that though things do change in the 30 years since these bikes were built, that's an old photo which could be up to 25 - 30 years old itself. Dylano, how long ago was that pic taken?
                        • Dylano*
                          • Apr 2014
                          • 202
                          #57
                          I will get a good scan of the image (that pic was taken with my phone)
                          And I will also be back with the exact year taken.
                          Have:
                          1994 FZR600
                          1982 XJ1100
                          Had:
                          1996 YZF600R
                          2001 Honda xr125
                          Suzuki race 80
                          Honda PW 50
                          Etc.
                          Getting:
                          1977 DT400
