enrichment levers
  • mack
    • 2411
    • Ontario, Canada
    enrichment levers
    If someone was very keen and needed some extra cash, he/she would come up with a replacement or repair for all these broken enrichment levers.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • D0wn5h1ft
    • Aug 2013
    • 515
    • Westerly, RI.
    Aren't they stamped steel? I supposed one could be milled out of some aluminum but it wouldn't be that pretty.
      Not all that hard to fix; I repaired the one on the '80 special I sold by fabbing a 3/32" aluminum replacement part for what broke off, overlapping it to the back of the lever and drilling/tapping it for a couple of 6/32 buttonheads to hold it on. Not noticeable unless you looked...
        • 8938
        I got rid of the lever, ran a 8-32 die over the enrichment shaft and threaded on a knob...
        • mack
          • 2411
          • Ontario, Canada
          functional
          yep those are functional for sure but not all that aesthetically pleasing. Out of all the bikes and all the carbs out there with broken levers, someone could build a nice little cash cow. Just saying...
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
            Yeah, what Phil and I did won't fly for a hard-core restoration but fits into the XS11 credo of 'cheapness' nicely....
            But that's a rather intricate stamping in pretty heavy gauge steel and not something easily repoed. But the part that breaks off is simple and could be easily made, do that and weld it on, have the lever replated and you're good to go. But not cheaply....
            • dpotter58
              • Aug 2004
              • 1866
              • Southern Maryland
              Mack, I have a NOS. If you need one PM me your address.
              1980 LG
              1981 LH
                • 2103
                Tip
                When cleaning /rebuilding the carbs it's a good idea to coat the enrichment plungers and the ball stops with silicone grease.
                It'll take the strain off of the lever.
                • MPittma100
                  • Aug 2011
                  • 2359
                  Levers
                  The enrichment lever rubber covers are still available. I know a lot of those go missing. Part number 2F3-14968-00-00.
                  1981 XS1100H Venturer
                  K&N Air Filter
                  ACCT
                  Custom Paint by Deitz
                  Geezer Rectifier/Regulator
                  Stebel Nautilus Horn
                  EBC Front Rotors
                  Limie Accent Moves On In 2015
                  Mike
                  • D0wn5h1ft
                    • Aug 2013
                    • 515
                    • Westerly, RI.
                    I did that too. I also removed the detent ball and spring on the #4 carb so it's only the one on the #1 locking the choke rod in place. This makes the choke MUCH easier to pull out and it still locks into each position!
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      If you have both pieces (if broken), they can easily be repair. The are just stamped steel. I just do a tidy little tig on them and re-enforce them along the back. Though, neither can be done pretty if it's chromed version.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
