Loud Horns
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    But the roadrunner analogy is totally on the spot!
    Never thought of it that way, now I kinda like my horn
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
      • 8904
      The 1980 models are the first year to have dual horns from the factory.
        Hi phil,
        Yeah, my SG came with two horns and if I'd bothered to look, Clymer's wiring diagrams agree with you.
        But those 2 pathetic bleats were hardly more audible than one.
        However, my Stebel-Nautilus does seem to attract attention, even from inattentive cellphone yakking SUV soccer moms.
        The horn is connected straight from the main fuse with 14ga wires, it's relay is triggered by the existing horn circuit.
        Dunno if the claimed 139dB is accurate but it's loud for sure.
        • MPittma100
          • Aug 2011
          • 2359
          Used Separate Horn Switch
          Hi phil,
          I tried to wire the new Nautilus to the existing horn circuit (Venturer) to no avail. Turns out that the pink wire that grounds via the push of the horn switch (with ignition switch on), grounds itself when you turn the ignition switch off - thus the Nautilus horn would sound off when I turned the ignition off? Don't know for sure, but it is quite possible that I have missed something.
          Mike
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
            The 81H has two chrome ringed horns mounted.
              Hey Mike,
              There's something wrong with your wiring then, that pink wire should only ground/complete the circuit when the horn button is pushed, that's where it finally goes to ground at the bars. SO...if it's grounding when you turn the key off, then that wire has gotten crossed with another wire in the harness or such!
              Hey Fred....put your ear 4 inches from it and it'll then be ~130 dbs!!! The 118 level is at 2 meters/6 feet away. No problem SloMo... I have brain farts also!
              • MPittma100
                • Aug 2011
                • 2359
                Thought So
                Hey Mike,
                I was thinking that something was wrong. Doesn't make sense that a wire would change polarity when you turn the ignition off. Everything electrically works on the bike. Not sure how this happened, but it did.
                Mike
                K&N Air Filter
                ACCT
                EBC Front Rotors
                Mike
