Loud Horns
  • MPittma100
    • Aug 2011
    • 2359
    Loud Horns
    I will give Yamaha credit for trying to improve the horn (noise) from the road runner sounding single that was installed on the 1979SF (Special) to the dual horns on the Standards and Venturers in later years.
    But , I have recently installed a real horn on my Venturer - The Stebel Nautilus.
    This horn and "loud" have a lot in common. When energized, it sounds more like a truck than a bike.
    I am really interested in seeing the results that I get with it.
    Mike
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    It really gets people's attention! I have scared the crap out of a couple people...
    • slow mo
      • 858
      • ontario canada
      i have the harbor freight Wolo bad boy horn 126DB plenty loud for the street ride safe slow mo!
      The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
      moemcnally@hotmail.com
      i AM THE KING OF NOTHING
      the people here are great , doesn't matter about the bike really/hamjam ////
        I was looking at that Harbor Freight horn. It says it draws like 40 amps? Basically everything my bike makes at full charge. I figure I'd hit the horn button and stall my bike? lol.
          • 6765
          I've had this horn on a few of my bikes...139 dB will wake up any brain dead cager...just make sure the horn is mounted in the vertical position...that is with the trumpets facing down...there is a little motor with an impeller that if mount horizontally will not function right and will cause considerably early failure...
          Also you need a dedicated wiring harness and relay...do not use the bikes wiring as the horn does draw alot of current and will fry the bikes wires...
          2005 Honda SilverWing 600
          2018 Honda PC-Xpress 150
            I have horns from an F150 on my SG. Peoples eyes get real big and they jerk their vehicle back into their own lane when they start drifting over on me and I hit the button.
            • MPittma100
              • Aug 2011
              • 2359
              Definitely
              Yes, I have wired this horn so as it is drawing directly off of battery through a relay. Has it's own wire harness totally separate from the bike.
              Mike
              K&N Air Filter
              ACCT
              EBC Front Rotors
              Mike
                • 4015
                This is the same as the Nautilus horn. Just branded differently.
                  As Ian just said, it is the same horn just a different brand.
                    More info on these horns
                    Hey Guys,
                    I checked the specs, the volume output is 118db, not 126.
                    The Stebel Nautilus "Compact" is rated at 115 db at 2 meters(6feet) and 139 db at 4 inches! It's rated for 12 or 24 volts, draws 18 amps at 12 volts, 9 at 24 volts.
                    The Harbor Freight/Wolo BadBoy #419 brand says it can use the existing vehicles wiring....auto, bike, etc.. Their bigger louder horn (BadBoyMax) comes with a 30 amp relay, but I'm pretty sure it doesn't use/draw 30 amps, they usually use a relay that is rated a bit higher than the required current that it will be handling. And the Owner's/Installation manual I just reviewed for the Regular Bad Boy says to use a 20 amp FUSE when using the Relay, so that jives with the Stebel's rated 18 amps!
                    I put on a set of the FIAMM El Grande Twins #74100, rated at 130 db / 4 inches, so very close to the BadBoy/Nautilus, only draw 10 amps, I still wired them with a RELAY so give the full battery power to them for the best volume, and they are only ~$20.00 on Amazon vs. the ~$40.00 for the Wolo/Nautilus clone.
                    • slow mo
                      • 858
                      • ontario canada
                      sorry about the 126 DB error it,s been a few years since i,ve seen the packaging!! ride safe slow mo!
                      • Tat2demon
                        • Jun 2012
                        • 718
                        • Sioux Falls, South Dakota
                        I did the same as TC and got the FIAMM El Grandes. Very happy with them.
                        Nate
                        78 XS11 "Matilda" 2H7 000364
                        K+N Air Filter
                        88 Voyager XII
                        81 XJ650 Maxim
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          Standards are supposed to have two horns??
                          I only have one, and only that one mounting point
                          79F
                          "Excelsior"
                          Honda gl1100 handlebar
                          Vetter IV fairing with speaker system
                          OE headers,Jardine slipons
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          Oe hardbags and luggage rack
                          TC fuse block
                          K&n filter with oe airbox
                          Raptor 660 Acct
                            • 4015
                            Spark- I can only attest to my F having one horn as well. I know I see pics of certain bikes with two, but I'm almost positive the early Standards came with one.
                              I am pretty sure that is true. My E only had one as well.
