Help!
    • 7821
    Help!
    I need an adjustment screw/spring for a Yamaha 25HP 4 stroke outboard. We started using a "holder" for the engine, and the adjustment screw backed out because of the vibrations. Yamaha does NOT list it as a separate part, and a new carburetor is $300 locally. I do not have the dimensions, but it is smaller than the idle screw on the XS. If you know of a place that sells used parts, it's a 2000 25 HP 4 stroke, F25 model. The adjuster is on the outside of the carburetor, near the engine intake.
    Just reply or PM me if you think you can help.
    Thanks in advance.
    have you checked www.boats.net?
      • 3973
      Yeah, the site shows five different F25 models.
      • jjz28
        • Apr 2012
        • 1023
        • Beckley, W. Va.
        would it be in this?
        SIM YAMAHA is your dependable, affordable, knowledgeable, authorized USA Yamaha marine outboard motor and YAMAHA OEM outboard motor parts, Yamalube oil and accessories dealer for two-stroke, four-stroke and jet pump motors.
        77 XS750 2D completely stock
          • 3973
          I think he is looking for the equivalent to one of our air/feul screws or idle screws. the rebuild kit you linked to Jeff are all internal parts.
          • jjz28
            • Apr 2012
            • 1023
            • Beckley, W. Va.
            oh crap I thought that spring was the one for the outside screw, I see it now.
              • 7821
              Yeah, what I need is a screw that Yamaha does NOT list in the parts fitch. I need to buy a $300 carb for the screw that fell out! If someone has a boat wrecking yard close buy, and could get me a phone number or web addy, I can try them. I just need the screw cheap and fairly soon. A used carb, even in poor condition will work for me, if it has the dam! adjustment screw. Oh, and the carb is the same for all 5 models....
              • rpgoerlich
                • Dec 2007
                • 643
                • Katy, Tx
                Might try Stone & Sons
                They deal mostly in older Evinrude/Johnson but do have alot of used parts.
                He might be able to at least point you in the right direction.
                Richard
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  There is a goofball guy in the parts section that lists like 400 used outboard motors for sale in his same post for 2 oil filters that hes been trying to sell for $15 for the last 4-5 years... he might have something for ya. Hes from Maine...
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                  '84 Chevy K-10 "Big Blue"
                    Carburetor# 65W-14901-50-00
                    Boats.net 1998 to 2003 CARBURETOR# 65W-14901-00-00
                    20 65W-1414F-00-00 JET, PILOT (#52) $21.30
                    21 65W-14147-00-00 O-RING $3.23
                    65W-W0093-00-00 CARBURETOR REPAIR KIT $27.60
                    No Pilot Screw/Spring/O-Ring is shown or listed even in the repair kit but the one in your carburetor fell out so... it's time to compare some Yamaha part numbers!
                    Boats.net 2006 and Later CARBURETOR# 65W-14901-50-00
                    No Pilot Jet or O-Ring is shown or listed but it has Mr. Pilot Screw and Friends:
                    29 67C-14923-00-00 SCREW, PILOT $12.93
                    30 67C-14397-00-00 O-RING $2.25 $1.88
                    31 67C-14555-00-00 SPRING $8.75 $7.20
                    33 67C-1432A-00-00 PLUG $8.25 $6.83
                    The later W00093-02 repair kit lists the Pilot Screw O-Ring but no needle or spring:-
                    65W-W0093-02-00 CARBURETOR REPAIR KIT $59.18
                    7 67C-14397-00-00 O-RING $2.25 $1.88
                    As far as I can tell the carburetors are almost identical and the both carbs share the Yamaha 65W part prefix.
                    Where did the Pilot Screw go on the early carbs and where did the Pilot Jet go on the later carbs? (shrug)
                      • 7821
                      Thanks, Scott!! I went to the site, and spent $36 for a little screw, etc. The good news, it's split 4 ways between the owners......
                        Yay!
                        Ray,
                        I hate to think that the good folks that make the parts diagrams and lists we all depend on were asleep at the switch. That's not a good sign!
                        Is it possible the engine is not a 2000 F25, or that someone stuck a more recent carb on it like I did with the '82J carbs on my '80G?
                        While I was browsing around I found a picture of a 65W carb with a part number stamped on one end of the carburetor body. I can't remember where I found the picture now but I think the number was below the throttle plate.
