Just ordered a colortune!
    Originally posted by sparkfly88
    Well,
    Colortune got here today..I had this WHOLE thing recorded on video, but the gopro overheated and froze, making the file corrupt...
    They mailed it in a bubble envelope..I ordered it from morgan.
    The box was flat on arrival, and the contents were strewn around.
    I went to cylinder one first.
    Plenty of spark, no fire. Well, thats odd I thought...ill get back to it thinking its just too light outside..
    Went to cyl 2.
    Saw color instantly.
    slightly rich, evened it out to blue with a hint of orange.
    cyl 3, same deal
    cyl 4, same.
    Went back to 1,
    Figured out itll only ignite the cylinder when revved higher...which makes the backfire which is what I've been chasing.....meaning bad coil.
    Funny thing is, that's a MikesXS black coil...only 2.2k on it. FAIL coil!
    Might as well splurge and get some of the Dyna coils..
    Anyone gotta good price check on em?
    If #1 is not firing at idle, neither would #4. Coil is NOT the issue, even though the black coils have a poor track record. May wanna cut back #1 plug wire for a fresh connection.
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      The wires are brand new as well
      Ive read about half the coil going bad....
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        Easy check, swap 1 with 4 and see if 4 is no longer sparking/firing.
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          Brilliant!
          ( now why didnt I think of that )
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
            I doubt that is your issue, because of the way the XS coils work. The charge travels down one plug wire, through the engine to the other plug, and up that plug wire, sparking both plugs each time. And your getting spark each time.
            Have you tried synching the carbs yet? On my GSX when I first put the carbs back together I forgot to bench synch. I went to synch them and no 1 had zero vacuum. I crapped thinking I had no compression (never had the bike running till then) or a bad valve, who knows...After cranking the synch screw enough I got vacuum on no 1.
            You may also want to try adjusting the mix screw, and make sure you have a good o-ring and spring in that synch screw. That can cause a vacuum leak.
            • sparkfly88
              • Mar 2013
              • 585
              • CedarKey FL
              I did have the carbs synced beforehand, all were even using the morgan carbtune.
              My carbs are the earlier ones, without the o-rings on the pilot screws.
              with the colortune on, I screwed the pilot out more and more, the ONLY time I would get fire from the color tune was at/around 2.5k
              79F
              "Excelsior"
              Hid headlight 6000k
              Stock jets
              Shinko 712 F & R
              TC fuse block
              Raptor 660 Acct
                • 8877
                I wouldn't worry too much, I'd just tune that cylinder by ear, the colortune can be somewhat quirky
                • TADracer
                  • 1417
                  • Kenner, Louisiana USA
                  Don't want to hijack the thread but I never thought that before. Each plug has its own secondary wire which should get the charge to each plug from the coil at the same time. Body of each plug is right to ground through the engine ground.
                  Does not seem possible....can you elaborate on this?
                  Mike Giroir
                  79 XS-1100 Special
                    • 9980
                    Photobucket ain't working for me today but here's the link to how I believe our system works. I agree.
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      Well, with the bike on idle, I screwed the pilot down all the way on cylinder one, and the bike wasn't effected all..
                      Does this I'm not getting fuel to cylinder one at idle??
                      I'm video taping the sync process for the forum, I synced last week, colortuned, and now I'm syncing again, cylinder One is lower than the other three, so that shows that the colortune did effect sync.
                      I decided to see how much, but the pilot in number one does nothing to it.
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                        • 9980
                        Those mixture screws break the tips off in the orifice pretty easy. Take that screw all the way out and look at the tip. It should be almost as sharp as a needle. If it's blunted it's probably broken off and your not getting fuel to that cylinder at idle.
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          So, at idle.... I can hold the header of cylinder one.
                          LOL that's not right.
                          79F
                          "Excelsior"
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          TC fuse block
                          Raptor 660 Acct
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            Just pulled out the mix screw, it's normal, and with a flashlight I can see through the hole..
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                              • 9980
                              Then the pilot jet or the cicuit itself is plugged.
                              The cylinder DOES fire off idle right?
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                Yeah, when I had the color tune in, you'd hear a backfire or a fire of some sort, then you'd see colors when it was off idle...
                                Sounds like I gotta go through my carbs.... Again.... Huh?
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
