Just ordered a colortune!
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    I can't wait!
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    • 3193
    You will either love it or hate it. I love mine but others do not agree. Waiting to see what you think of it as well.
      • 8928
      They work great with high output aftermarket coils, not so well with the stockers, YMMV
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        Good thing I don't have stock coils.
        I love the concept of how it works, I know the shop set mine using header temp... I just don't feel that is enough.
        I want to actually SEE what I'm doing.
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
          • 4012
          My experience with it (stock coils) is u cannot really understand what's going on after a certain point. it's like "do I see orange?" I have them tuned to a decent spot (not perfect), and that's where they'll stay for now. I'd love to get my bike on a dyno and have them tuned according to the graph. I know Scott hooked a lean/rich meter to the pipes (via an O2 sensor) and tuned them accordingly. Not sure how accurate that is, as an O2 sensor was only in one header. I'd actually like to do that again.
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            Well I finally got the bike in time at idle using a timing light. It was at least a quarter of an inch off from the F line.
            Still waiting on my colortune to get here.
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
              Here id the hitch to the colortune. You can not set the plug gap on it, it is set at the factory, done. So you will notice that it will not hit 100% of the time, some missing does occur.
              The way I always adjust with it is to take the mixture screw out till I go from blue to a good yellow flame. Then hit the gas a little, let it idle up and then back down, when it settles should still be yellow flame. Now turn the screw in till you just start getting all blue flame, back the screw out about 1/4 turn.
              A better way to tune is by max vacuum if you have good gauges or carb sticks. It is not a big change, but you can see it change as you tune. Then re-synch the carbs.
              No matter what method you use, I still recommend to look at the plugs after a few hundred miles and adjust on what you see on the plugs.
                The problem with the Colortune as far as I can see is it is useless beyond the idle mixture adjustment.
                Your much better off with a decent set of vacuum gauges and some knowhow and understanding of how the carbs work. That's free and available to all.
                No magic tool other than some basic knowhow.
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  I have a Morgan carb tune. The problem is, I cannot see the change, the sticks hop around too much for me to see the pilot adjustment.
                  And yes... I have the tool setup correctly with the little orifices inserted into the line where the manual says.
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                    My merc stixs have done that when there was a low voltage to the coils down at an idle......JAT.
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      That's a good point. I think I synced it to my old oe coils.
                      The shop synced it with the new coils, I wonder if it'll be smoother...
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        Well,
                        Colortune got here today..I had this WHOLE thing recorded on video, but the gopro overheated and froze, making the file corrupt...
                        They mailed it in a bubble envelope..I ordered it from morgan.
                        The box was flat on arrival, and the contents were strewn around.
                        I went to cylinder one first.
                        Plenty of spark, no fire. Well, thats odd I thought...ill get back to it thinking its just too light outside..
                        Went to cyl 2.
                        Saw color instantly.
                        slightly rich, evened it out to blue with a hint of orange.
                        cyl 3, same deal
                        cyl 4, same.
                        Went back to 1,
                        Figured out itll only ignite the cylinder when revved higher...which makes the backfire which is what I've been chasing.....meaning bad coil.
                        Funny thing is, that's a MikesXS black coil...only 2.2k on it. FAIL coil!
                        Might as well splurge and get some of the Dyna coils..
                        Anyone gotta good price check on em?
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          • Virginia Beach, VA.
                          You can try the Honda VF coils too. I'm running some on my SG and they wrok great.
                          80G (Green paint(PO idea))
                          The Green Monster
                          Got him in '04.
                          bald tire & borrowing parts
                          Scarlet
                          Got her in '11
                          Ready for the twisties!
                          81H (previously CPMaynard's)
                          Hugo
                          Cold weather ride
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            On ebay....the Dyna coils are only 120$ for the pair???? With a 1 year warranty...
                            If I looked at that better earlier, I wouldnt have gotten the mikesXS coils.
                            I thought it was 120 PER coil.
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                              Several people have had trouble with Mikes coils not lasting long, especially the black ones.
