Most replaced part(s) ?
    Originally posted by GLoweVA
    Totally agree on the speedo. I'm on my 3rd with the G and my 2nd with the SG. I think with the 80/81's that only go to 85mph, once you hit that peg, forever more that speedo's life is shortened.
    Mine hits the 85mph peg just about daily. If you go in and lube the little worm gear in there, it would help. Bumping that maxed out peg does nothing to it since there's really nothing touching in there to raise the needle up. It's simply a magnet getting pulled by a bell. But if that's the excuse you use to keep you under 85... whatever works for you! lol.
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      Don't have to worry about it now:
      Although, the xs400 speedo is a tad bit smaller than the 750/850/1100 ones, it still bolted right up and is accurate up to 95mph that I know of.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
      • ViperRon
        • Feb 2011
        • 1062
        • Woodstock, VA
        Brake cylinder kits and master cylinder kits do need to be replaced often if you want to stop. Tires are replaced more often these days and since you repack grease in bearings then grease seals need replacing. If you use head cover gasket its probably replaced within 10,000 or less because of valve adjustment. The boots from cylinder to carb tend to crack quickly and the little nippples on the vacume ports go bad quick.
        Valves are damaged far to often but that's often due to confusion.
        Rodan
        1980 G Silverbird
        1198 Overbore kit
        Grizzly 660 ACCT
        Barnett Clutch Springs
        R1 Clutch Fiber Plates
        122.5 Main Jets
        ACCT Mod
        Mac 4-2 Flare Tips
        Antivibe Bar ends
        Rear trunk add-on
          • 6765
          with my XJ i went thru 4 different exhausts(not including the original) before finding the Kerker
          2005 Honda SilverWing 600
          2018 Honda PC-Xpress 150
          • Cobia
            • Jul 2007
            • 1587
            • Palm Beach County, Fl
            I'm on my third set of handlebars due to rusting. I live close to the ocean and the salt in the air is murder on any and all exposed parts. I don't have a garage.
            1980G Standard, Restored
            Kerker 4 - 1
            850 Rear End Mod
            Automatic CCT
            1980GH Special, Restored
            '82 XJ1100 (Sold)
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              A bit pricey, but what isn't?
              This stuff would save you money in the long run. I don't know how it would work on exhaust systems, due to heat, but on the rest of the brite work, it is the answer.
              Intelligent search from Bing makes it easier to quickly find what you’re looking for and rewards you.
              CZ
              • Newbee
                Truly XSive (Deceased)
                • Jul 2011
                • 160
                • Whitby Ontario, Canada
                replaced
                80 xs11g replaced motor with 81sg motor which is about 5mph slower speedo cable rear brake master cylinder twice starter motor twice fuses need to up date but other than that not much still running great to this day.
                • Cobia
                  • Jul 2007
                  • 1587
                  Thanks CZ,
                  I've heard of Shark Skin. I'm going to have to find some and try it out.
                  Kerker 4 - 1
                  850 Rear End Mod
                  Automatic CCT
                  '82 XJ1100 (Sold)
                    • 8905
                    Robert, it's called Sharkhide....
                    Protecting marine, automotive, and motorcycle projects from the elements for 40 years! Maker of the world's best metal protectants, cleaners, polishes.
                    • RS Thornton
                      • Jul 2003
                      • 343
                      • Spring, Texas
                      pickup wires
                      I think I have finally found wire that will work but I am failing a set every year. Guess it does not help that replacements are same age as failed ones.
                      I have a bike and I am not afraid to use it
                        • 8064
                        Okay, I have one that hasn't been mentioned yet. Clutch Springs!!! Of course that's partly because I used some standard generic ones from Partsnmore the first time, and just a couple of years later they were slipping again, and this was with NEW frictions.
                        EBC clutch springs are wimpy.(10% stronger than stock) Vesrah clutch springs are stronger than stock. Ferodo clutch springs are heavier still. Barnett has the heaviest duty clutch springs.
                        I've had my SG for 10 years and 50K miles. I can't think of anything I've replaced more than once. The exception being tires and oil filters.
                          • 9981
                          The only thing I can think of that I've replaced several times is gauges. I've gone through probably 5 speedometers and 3 tachs. I need another tach on the SG right now.
                            • 8064
                            Now that you mention it, I need to replace my tach for the 2nd time.
