Traded a Mossberg 590 for a 1979 yamaha Xs 1100 and new to forum
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    I'm just tryin to make it bearable
    "nice" stuff for this bike will come later, function first
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
      Hi Kyle and welcome,
      if installing the not quite right replacement seat starts giving you grief, you can always try to salvage the existing rusted away seat pan.
      Sandblast the remains to provide a good key for the 3 layers of fiberglass that you put over it.
      The little teeth that hold the cover on will most likely have snapped off when the cover was removed.
      They can be replaced with strips of teeth that pop rivet on.
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        Well, found out my brake issue today.
        Everything was dry.... The slides, and the sleeve that slides in the rubber boot. It was all sized up. But, NO LONGER.
        Next issue. I attacked the fuel lines....
        I guess the previous owner was only running two cyls?
        Only the bottom T on both sides had a line going to it.
        Are they all supposed to have lines to them?
        Aka off each petcock, an inlaid filter...a Y, then to both carb T's?
        Then, it looks like each manifold has a vac port on it... Along with the #2 carb from the left?
        Each outside port it plugged, along with the port on the carb facing the engine.
        I assume the open vac ports connect to the petcocks.
        I'm having a blast working on all this.
        Thanks for all the help everyone
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          #34
          Found a portion of a post stating this... By a certain cat
          78-80 carbs have 2 sets of inlets, the LOWER ones which are the*fuel*inlets, the UPPER ones are the bowl vents only and no*fuel*lines should be connected to them, but they need to be OPEN to air/vent, otherwise if capped off, will cause the carbs to flood.*
          Guess that answered part of my question.
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            #35
            The whole right rear of the pan is rusted away basically.
            I guess when I thought it was in half, was because the whole cushion is able to move.
            I hope this 1980 seat isn't too hard to install..... :/
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
            • xs11jack
              HALF GURU
              • Nov 2002
              • 606
              • O'Fallon, Mo.
              #36
              Hello 88, welcome to the best place south of the north pole for Yamaha knowledge. As you know by now we have the most eager helpers there are. We are glad you found us. Good luck with the bike.
              Ole Jack
              J.D."Jack" Smith
              1980G&S "Halfbreed"
              1978E straight job
              "We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
              Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
                #37
                Hey again,
                Yep, lots of info available when you search. The petcocks on a standard are Vacuum actuated, so that's why they get connected to 2 of the intake boot ports. However, the #2 carb body port is ONLY for the vac. advance hose that "should" be coming from the left timing cover...vacuum pot underneath it. The carb port is metered and controlled by the throttle shaft butterfly which is required to properly control the vac. advance function.
                Hopefully on the brake calipers, you took the square O-ring out of the groove and cleaned/scraped the corrosion that builds up in the caliper groove which can put excessive amounts of pressure on the caliper piston preventing it from sliding back and forth. Also, check out the tech tips for the SPOOGE HOLE repair/fix for the master cylinder. Some/many folks still use their OEM Vinyl brake lines. But others complained of poor braking response/affect, and after installing braided stainless steel lines, there was a significant improvement in stiffness and such. Just a thought for a possible improvement in the future, I know you're just trying to get it up and running without sinking a ton of $$ into it.
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  #38
                  Okay. So the capped off intake boot is supposed to go to a vac advance... Lol.
                  I'm sure that'll help it run alot better.
                  I disassembled and cleaned the brakes according to what I'm used to doing when I was an aut tech.
                  I don't remember seeing any square o ring. I removed the pads, and slides, greased the contact points of the slides And caliper.
                  I'll start posting photos eventually, I use my phone mainly and I wish the forum used Tapatalk like my others.
                  I remember going through and finding the fabled spoog hole on the forum.
                  And your correct, before I drop a ton of cash into it, I want the basics running. Then I'll know it's worth it.
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                    • 3193
                    #39
                    You have to remove the caliper piston from the caliper to find and clean this square o-ring. It gets a bunch of gunk built up behind it and needs to be cleaned.
                      • 8938
                      No, the vac advance goes to a port on the front of carb body #2, the 4 intake boot ports should be either capped off or running to the 2 fuel taps to let the gas flow when the engine is running.
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        #41
                        Sorry, I forgot I removed the lines from the intake boots.
                        I meant to say the port that is capped off on the back of the carb
                        Tomorrow I will definitely look into it.
                        I bought 4 feet each fuel and vacuum line just for this reason.
                        When I get everything up to snuff, I plan to totally rebuild the calipers. The previous owner decided to spray the left front down with something like lithium or pb blaster, and it ate all the rubber dust covers...
                        This bike has a little bit of everything wrong...... Lol
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                        • CaptonZap
                          • Jun 2010
                          • 1748
                          • Denver
                          #42
                          Take another look. The timing vacuum port is a brass tube that sticks up and out from body on the front of the carb , just to the left of the idle screw on number two carb. (the carb second from left)
                          It is situated so that the vacuum increases with increased air flow through the carb, (open throttle), unlike the ports on the rubber intake boots which have increased vacuum when the throttle is closed.
                          If your carbs have a port on the back, they are not stock for an XS11.
                          CZ
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            #43
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                              Yep, you capped off the vac. advance port! At least you KNOW what to hook up to the advance unit behind the left cover.
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                #45
                                No, the previous owner gave it to me like that. I don't know what's heads or tails on half this bike lol. Sorting wiring, switches..etc.
                                This is how all my projects come to me. Clueless owners that don't like to learn...
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
