The internals of the engine rotate like a log rolling toward the rear of the bike. Standing on the kickstand-side, it is rotating clockwise. The thrust of this motion pushes the case and frame in the opposite direction, pushing the front wheel downward, and lifting the rear.
wheelies 101
-H. Ford -
... Deleted.Try your hardest to be the kind of person your dog thinks you are.
The engine does rotate towards the rear of the bike torquing the front down which is completely opposite of others that torque towards the front torquing the front upwards. The case will try it's hardest to turn in the opposite direction of crankshaft rotation.
Ride a Suzuki or Kawasaki 1000 or 1100 and see how easy it is to pull the front wheel up. It's not because they have more power it's because the engine torque lifts the front.
You see drag cars when they take off from the line and the left front wheel lifts? That's because the engine is turning to the left and the engine block is trying to spin to the right and actually twists the frame.Greg
The list changes.Comment
I've read this a couple times now and it makes no sense. The motor rotates backwards, meaning clockwise, meaning it's spinning a direction that would be more inclined to RAISE the front from torque. Is this just one of those rumors that someone heard and ran with it?
Also, what makes the rear want to rise has nothing to do with the motor, but the gears trying to climb up each other.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
We HAVE 11 second bikes, in therory I've never made a run to find out, so by what your saying we should be able to pull the wheel easily because the suspnsion smashing that rear wheel into the ground certainly gives you a "hook up" just like a set of traction bars, and we should except we are fighting engine torque. I think it is a helluva design myself.Last edited by BA80; 09-15-2012, 04:30 AM.Greg
...so by what your saying we should be able to pull the wheel easily because the suspnsion smashing that rear wheel into the ground certainly gives you a "hook up" just like a set of traction bars, and we should except we are fighting engine torque. I think it is a helluva design myself.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
Yup, popping the clutch will do it, not quite as easily with the taller gears in the FD but doable. The horsepower will overcome the downward torque.
Not trying to argue or anything but anyone with the knowledge of the effects of torque will have to agree that with the engine turning the direction it does will torque the front of the engine down and since the engine is attached to the frame it will have an affect on pulling the front up. That is simple physics.Greg
I agree about the suspension our engines turn on a different axis than a car. Here's a video of my manager where I works' white S10. If you watch closely the right wheel lifts before the other one. http://youtu.be/6LjMJgTj48A .
We HAVE 11 second bikes, in therory I've never made a run to find out, so by what your saying we should be able to pull the wheel easily because the suspnsion smashing that rear wheel into the ground certainly gives you a "hook up" just like a set of traction bars, and we should except we are fighting engine torque. I think it is a helluva design myself.Last edited by motoman; 09-15-2012, 12:50 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Stock gearing two-up, even carries a ways in second, and full dresser to boot, but that was a couple decades ago performing these kinda antics giving no thought to the actual abuse created. Tods pictures show exactly how all that finially takes a toll on vital parts.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
8500rpm full throttle held speed shifts.
Power curve starts dropping earlier than that. It fallas off pretty good after @ 7500. I like to keep it in the 6k to @ 7300, but it actually peaks on a dyno in stock form just under 7k.
So.. you might have got that extra half second riding it in the zone.. assuming the Venturer is similar.Try your hardest to be the kind of person your dog thinks you are.
So.. you might have got that extra half second riding it in the zone.. assuming the Venturer is similar.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Ehh... Some of US are as big as barn doors and push almost as much wind on a naked bike as that fairing. With the old Shoei fairing I had on, it actually gave me a higher top end and better MPG than no fairing. It cut the wind really well. It was broken in several pieces.. it and guardrails don't play well together. I have a guy that has been SLLLLLOOOOOWWWWLLLLY putting it back together, but he has a new kid with another on the way and hasn't had a lot of time to work on it. They are apparently like hens teeth though. I tried calling Shoei and asking for some parts (A new turn signal) and got a kid saying, "We don't make fairings, we just make helmets.." Finally talked to one of the old hands in the back shop and was told they haven't made fairings in over 20 years. I found where I can buy a new OEM one, but they're @ $450 and they only had a white and some other color, so I'd have to get it painted on top of that cost. This is a pic of it on the bike when I actually would clean and polish the bike occasionally. lol.
Last edited by motoman; 09-16-2012, 11:26 AM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I fixed my wheelie problem...since its got more power and torque than an XS 1100, and the engine turns the right way, I put on wheelie pipes!
Seriously does have more power and torque than the 11, just weights almost twice what my G did!!Healthy is merely the slowest rate at which you can die
Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. ThompsonComment
