My XS11 Progress Thread
  • Bassman
    • Aug 2012
    • 59
    • Fort Collins, CO.
    @John nice spot on the black bear, I was wondering if anyone would notice My dad shot it in Canada last year and is in the finishing stages of making it into a rug
    @hamjam fender for sure
    @BA80 I agree that its a bummer for the frame to be hacked like that, but hey, I can try something new and make it look cool! (hopefully)
    -Andrew
    80 XS11 G: Project bike
    • Bassman
      • Aug 2012
      • 59
      • Fort Collins, CO.
      Trouble, thy name is wiring
      So, it seems that the PO did a bit of re-wiring...not a pretty sight and probably the reason for the fusebox fire.
      This is the fusebox now. I will be mapping out the wiring by hand to see what is missing and/or changed from original in order to find out what needs to be done to get it running again.
      Along the way, I realized that I am missing a flasher relay. Is this something that I will be needing right away to get it running? Secondly, does anyone know of a replacement part and where I might be able to order it from? I checked on the Yamaha website, but it will not allow me to put anything into my wishlist.
      Thanks guys.
      -Andrew
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        Along the way, I realized that I am missing a flasher relay. Is this something that I will be needing right away to get it running? Secondly, does anyone know of a replacement part and where I might be able to order it from? I checked on the Yamah web site, but it will not allow me to put anything into my wishlist.
        Thanks guys.
        You wont need a flasher relay to make it run, just to make it road legal. These bikes came with a 3 prong flasher and have an auto cancel function. If you dont care to keep that function you can pick a 2 prong one up at the auto parts store for cheap. Try shearching for a few key works like flasher or flasher relay and you might stumble across the part number I posted... (use the advanced search function and you can search posts by members names, my name might produce a part number from auto zone).
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
        • Bassman
          • Aug 2012
          • 59
          • Fort Collins, CO.
          I took a break from looking at the wiring diagram today and decided to redo the seat. As you can see from the pics at the beginning of the post, it was partially burned and pretty ratty.
          I used this site as a guide. It has a bunch of great info if anyone is interested:
          Here are a couple of pics as well:
          An electric bread knife works incredibly well for shaping the contours.
          -Andrew
          • jwhughes3
            • 2798
            • Home of the Alamo
            That Granite seat looks very hard!
            John
            '81 XS1100H - "Enterprise"
            • Bassman
              • Aug 2012
              • 59
              • Fort Collins, CO.
              But at least it looks good and doubles as a cutting board!
              -Andrew
              • Bassman
                • Aug 2012
                • 59
                • Fort Collins, CO.
                Update
                So I finally caved and bought a replacement wiring harness and wow, what a difference!Things actually match the wiring diagram!
                Anyway, my newest problem that I have run into is my ignition. It seems the PO was just going to strip it all down and just have a manual hand switch to turn the bike on and off and, thus, cut all of the wires off of the ignition. This is not such a big deal as I can replace the wiring. What does seem to be an issue is that the ignition will not turn to the "park" or "lock" positions.
                Does anyone have any ideas for how to fix this? Or should I just get a new one?
                Thanks,
                Andrew
                -Andrew
                  You have to have the steering turned all the way to the right or left to get it to lock. I have to kinda wiggle mine to get it to turn. Be sure not to leave it all the way in the park position very long or it will kill your battery. BTDT.
                  In the park position your tail light stays on.
                  • Bassman
                    • Aug 2012
                    • 59
                    • Fort Collins, CO.
                    Haha, I haven't even gotten to the point where I could deal with that problem!
                    The problem I am having is that the key will not even turn to the left past OFF.
                    Thanks though!
                    -Andrew
                    • Bassman
                      • Aug 2012
                      • 59
                      • Fort Collins, CO.
                      Nevermind, WD40 is incredible and worked like a charm!
                      -Andrew
                        And now you need to pull the ignition switch out, take it apart and actually clean it. WD40 gets VERY sticky and gummy after it dries. Clean it with silicon spray and then lubricate it with graphite.
                        • WMarshy
                          • Apr 2009
                          • 2402
                          • Mexico NY
                          For another month or two... +1 What Nate said...
                          '79 XS11 F
                          Stock except K&N
                          '79 XS11 SF
                          Stock, no title.
                            Hi Andrew,
                            WD40 is NOT a lubricant or a penetrating oil although it's carrier fluid does a kinda OK job at either.
                            That aside, good luck with the resurrection.
                            If the mad butcher didn't throw out all the parts he unbolted or sawed off, try if you can retrieve them and weld them back on.
                            An XS11 has the potential to be a great chick magnet, but with only a solo seat, not so much.
                            • Bassman
                              • Aug 2012
                              • 59
                              • Fort Collins, CO.
                              @fred- thanks for the tip, but SWMBO might take offense at my trying to pick up chicks!
                              Well, I got it to at least turn over last night, but not when I push the starter button. I will spend tonight troubleshooting the off/run/off switch and trying to figure out why it will not fire when I push the button (the headlight comes on when I turn the key, but no power to the starter button).
                              I will also be taking apart the ignition switch and cleaning it!
                              -Andrew
                              • Bassman
                                • Aug 2012
                                • 59
                                • Fort Collins, CO.
                                Here is another progress picture for your enjoyment (I am on the left)
                                -Andrew
