Alrighty then,
We know that as far as we can tell, the ignition is working up to the coils, so lets think about what comes next. ( The pickup wires are what make the TCI pulse, so for the time being, lets figure they are doing their deed).
(You didn't tell us what the voltage was to the coils, but we will assume that it was around 12 volts. If it wasn't, go charge the battery, and we'll try again.)
Next in line is the plug wires and caps. You said that you checked the resistence and they were in spec. What you didn't say was if the wires were hard and cracked. High voltage just loves to slip out through the cracks, along dirty wire surfaces, and so to ground. Low voltage in the ohm meter doesn't leak.
Next in line is the spark plugs. They can get cracked, from being dropped, and there is another path to ground for the high voltage. Have you taken them out, and looked to see if they were fouled? If they are black, that would cause a misfire. Starting with the "choke" on full, will cause a fouled condition if the spark is weak, as would be the case if the voltage to the coil was low.
Another problem could be that someone has made the coils fire without there being a gap to ground. Like they took off the caps, took out the plugs, and took a compression reading. The internal voltage of the coil, with nowhere to go, got high enough that it poked some holes in the insulation of the high tension coil windigs, and now when it fires, the output voltage is low, since the current isn't going through all the windings . The leakage would only show up when the coil fired, so the resistence would read OK when measured with an ohm meter.
But lets check it, while we're here.
Put the plugs in the caps, lay the plugs on the metal cylinder head, so that you can see the gaps. Turn on the ignition, and crank the starter.
Each of the plugs should show a fat blue spark. The plugs are paired 1 with 4, and 2 with 3. So if any two of those pairs shows a weak blue, or yellow spark, you have an indication that that coil may not be up to snuff, or that the plug is fouled and the spark is running down the side of the center electrode to ground. Swap plugs with the other pair, and try the test again. Same result? Must be the coil, not the plugs.
That should give you enough to keep you busy for an hour, I'll check back for the results.
CZ
