I’m so freakin close I can taste it (gas, carb cleaner, brake fluid, motor oil,etc…). The bike is running well but still needs the carbs synced. I’ll do that tomorrow. I now have a bit of an electrical issue. I took off the fairing and am building it naked. A couple of issues: my head light doesn’t work and looking at the schematic it looks to be connected correctly. Other symptoms are no back light on the speedo or tach. The brake light doesn’t come on when I hit the back brakes but does when I hit the front brake. The turn signal won’t flash but the relay clicks. All the fuses test good and as I mentioned the wires look to match the schematic.
Thanks
Jason
Thanks
Jason
