FWIW T.C, the sealed bearing CAN be re-packed. Just pop them in one of the two piece cone type wheel bearing packers from NAPA and pump away. Grease goes by the seal and no damage to outer seals of bearings. Haven't found a sealed wheel type bearing that this doesn't work on.
New to forum
FWIW T.C, the sealed bearing CAN be re-packed. Just pop them in one of the two piece cone type wheel bearing packers from NAPA and pump away. Grease goes by the seal and no damage to outer seals of bearings. Haven't found a sealed wheel type bearing that this doesn't work on.Nathan
Theodore RooseveltComment
Really Nate. . .we're talking about the usually Unobtainium large left rear bearing that will probably again be Unobtainium once James sells his "cluster" of 22! Repacking them to possibly rejuvenate them to possibly help them from wearing out may help keep many XS's on the road instead of being sidelined for lack of a replacement bearing.
Thanks Motoman!
T.C.T. C. Gresham
I seen somwhere here where someone modified the tailight with LEDs. Wondering if anyone has just simply tried the LED replacement bulbs like these?
http://www.superbrightleds.com/cgi-b...8-T.htm#photos
That's some newer design and technology compared to some of the regular styled LED bulbs that have been tried before! However, if you'll look around their site... IIRC truck or boating or such, you'll find some with a bulb socket attached to wires that connect to a large ARRAY Printed Circuit Board with a nice wide spread of LEDS, 36 or so count that can be simply hot gun glued to the inside of the brake light reflector, so can be reversed and retain the OEM sockets, and are probably much cheaper than those fancy high powered tower design bulbs!?
T.C.T. C. Gresham
Thanks Motoman!
T.C.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Thanks Motoman!
Last year when I replaced all the wheel bearings I ordered the other 3 bearings for about $9 shipped to my door.Nathan
Welcome ladd!
I didn't have time to read all the post, but I like to welcome new members.You will find lots of useful info and comeradery here.
Special EdOld bikers never die, they're just out of sight!
My recently re-built, hopped up '79 Special caught fire and burned everything from the top of the engine up: gas tank, wiring, seat, & melted my windshield all over the front of the bike.Just bought a 1980 Special that has been non oped for 9 years. My Skoot will rise from the ashes and be re named "The Phoenix!"
I've been riding since 1959.Comment
Hey Zeke,
T.C.80 XS1100 SG "Iron Horse"Comment
