New to forum
    Hey James,
    Thanks for chiming in...my CRS got to me and I didn't try to open another browser tab to find your name! Again, I get to talk and prove that I'm just a shadetree survivalist....I haven't actually had my left rear bearing out of my wheel. I've had the rear wheel off many times for tire changes and work on the swingarm and such...but I didn't know that the bearing wasn't SEALED...that you could get to it to remove old grease and repack it??? I could have sworn that the NEW one you sent me was sealed!
    FWIW T.C, the sealed bearing CAN be re-packed. Just pop them in one of the two piece cone type wheel bearing packers from NAPA and pump away. Grease goes by the seal and no damage to outer seals of bearings. Haven't found a sealed wheel type bearing that this doesn't work on.
      Why bother when a couple bucks buys a new bearing.
        Really Nate. . . we're talking about the usually Unobtainium large left rear bearing that will probably again be Unobtainium once James sells his "cluster" of 22! Repacking them to possibly rejuvenate them to possibly help them from wearing out may help keep many XS's on the road instead of being sidelined for lack of a replacement bearing.
        Thanks Motoman!
          Originally posted by Zeke on Wheels
          I seen somwhere here where someone modified the tailight with LEDs. Wondering if anyone has just simply tried the LED replacement bulbs like these?
          http://www.superbrightleds.com/cgi-b...8-T.htm#photos
          Hey Zeke,
          That's some newer design and technology compared to some of the regular styled LED bulbs that have been tried before! However, if you'll look around their site... IIRC truck or boating or such, you'll find some with a bulb socket attached to wires that connect to a large ARRAY Printed Circuit Board with a nice wide spread of LEDS, 36 or so count that can be simply hot gun glued to the inside of the brake light reflector, so can be reversed and retain the OEM sockets, and are probably much cheaper than those fancy high powered tower design bulbs!?
            Thanks Motoman!
            Welcome T.C......was just something I had done many years ago out of curiosity and it worked...........and Nate, was referring to sealed bearings in general. Just was offering an option to those who by their location may not be able to just run out and by a replacement bearing when the one they have rotates smoothly and could use a re-packing. Most sealed bearings have a minimal grease in them anyways, and I commonly choose to do this with a new one anyways if rotation is too easy. Having said that, remember, being the net, you actually have no real knowledge of my mechanical backround, nor do I of others......tread lightly.......
              Thanks Motoman!
              If you read the quote from motoman, he never once mentions the left rear bearing, only the other regular sealed (left rear is not sealed as you just found out) bearing in the wheels.
              Last year when I replaced all the wheel bearings I ordered the other 3 bearings for about $9 shipped to my door.
              • Special Ed
                XStremely XSive "Mad Monk"
                • 808
                • Monterey CA
                Welcome ladd!
                I didn't have time to read all the post, but I like to welcome new members. You will find lots of useful info and comeradery here.
                Special Ed
                I've been riding since 1959.
                • Zeke on Wheels
                  • Jun 2012
                  • 38
                  • Frederic, Mi.
                  Hey Zeke,
                  Thanks T.C. I will have to check them out.
                  80 XS1100 SG "Iron Horse"
