dead battery? nope im a dipstick.
    Originally posted by planedick
    If you can't figure out what happened before you push it a long ways, maybe you shoudn't be astride something that's gonna bring things to you quite so fast. I've tried to start many times after leaving it in the off position. Takes me less than 5 seconds to figure what's wrong. If you were an AMA member, they would come rescue you for free.
    Well, the added info to that one is that I had been having issues with the bike and was making some "corrections", so when it quit, it seemed as if my repair had failed. Which is why I did not think of the petcocks right away.
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      Originally posted by motoman
      +1...........from first-hand experience also.........that kill switch was the fartherest thing on my mind.......as should be. Also understand the MSF reasoning, but 'real-world' is totally different......just sayin....
      On top of that, on THESE bikes if the tipover switch is working and the bike ends up on it's side, the engine is already stopped anyways so the kill switch is a moot point.
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        Still needed
        I only use the kill switch when necessary, ie: When parking on an area where it's necessary to keep the right foot down and also hold the break while turning it off in gear to hold it there when I get off. I know almost never, but it has happened and it was real handy.
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
        • STEPPENWOLF
          • Jan 2007
          • 4188
          • CINCINNATI OH
          I don't use the kill switch..my opinion is it is on the wrong side of the handle bars to begin with...you drop your bike,the XS shuts off but on other bikes your throttle is jammed into the ground,full throttle in gear,kill switch is wayyy down low..it should be on the left bar sticking up in the air easy to get to vs key or kill switch on the right bar...just my thought.
          '80 XS1100 SG
            - - - If you were an AMA member, they would come rescue you for free.
            Hi Dick,
            but consider the scene when the AMA tech flips the killswitch back to run and you wish it were possible to die from writhing embarrassment.
              • 3192
              Only time I ever use the kill switch other than an emergency situation is to do a high speed chop. Other than that it is a useless trinket my bikes have.
                I will hit the kill switch and coast into a parking spot or into my garage, then the exhausts fumes don't follow me .
                  Nate, umm...I don't think that is the bike your smelling.
                  If your exhaust follows you in a parking lot, you might want to change your diet.....or the bikes rings and seals.
                    I have new gasket and all for the exhaust, just haven't gotten around to it yet.
                    • va_blue_stang
                      • Aug 2011
                      • 97
                      • Bluford Il 62814
                      I parked mine in a parking lot with slight incline and left it in gear. Came out after a few minutes and worked for about a half on it till I realized it was in in gear and wouldn't crank
                      82 XJ1100
                      Very Little that is factory left.
                      Large mix of XJ/XS parts
