Two stroke oil
  • Poprock
    • Apr 2005
    • 594
    • Oregon Coast
    Used to have a Ford F 100 with a 232 6 banger. The valve cover would fill up with a yellow foamy sludge running Penzoil. Mobil cleaned it out.
      • 3273
      Read that test via another forum this spring, didn't catch this thread until today.
      I ran the specified two stroke oil in all my vehicles through the summer, at 1 oz per 5 gallons. Can't say I noticed any improvement in fuel economy or otherwise. However from the test, I do believe it is minimizing/elimination the effects of ethanol on the fuel system, and that is enough for me to keep using it.
      ZRX1200
      Seca 750
      • latexeses
        • Jun 2008
        • 1491
        • California
        Any Conclusions
        Been a while since this went around. Just wondering if anyone has anything like long term evidence that it helps.
        Just wondering by.
        Everything on hold...
          #34
          Just wondering by.
          I went all last season using a mix of 3-4 ounces each of 2 cycle oil, seafoam, and Lucas upper cylinder lube. Didn't really see any difference in anything.
          • MPittma100
            • Aug 2011
            • 2359
            Willing to Try It
            I will try it and see. I did notice that the Pennzoil Marine 2 is no where near $10.00/gallon as he suggested - more like $25.00/gallon.
            MP
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              #36
              I tried it for a few months and saw no noticable change in MPGs, but I did see a little better throttle response. I think that was due to the internal parts of the carbs getting a little lube.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
              • kflyboy
                • Apr 2012
                • 81
                • Lakewood, Colorado
                #37
                Two stroke Oil
                I have been using this 2-stroke oil for a about 3 months. The plugs look really clean and my bike seems to run really well at 70,000 miles. Only uses about a half pint of oil in 2,000 miles between oil changes. I keep 2- 5 gal. cans filled with gas and the oil added and just gas up at my place. It is cheap at Wal-Mart. I am going to keep up with it for at least the rest of the season and check the plugs then. So far, so good.
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  #38
                  Originally posted by planedick
                  I've been using MMO for years and I think it has all the advantages of the 2 cycle oil. Just squirt some in whenever I think of it....
                  +1, on my X650s I could tell when another MMO treament was needed, about once a month. I was driving 90 mi. round trip to work. That was back in the late 70s-early 80s, ethanol was not available. Could hear the difference in the sound of the engine. Deaf on the left but if you need someone to check out your car, truck or bike the right ear hears what the mechanics don't even notice.
                  76 XS650 C ROADSTER
                  80 XS650 G Special II
                  https://ibb.co/album/icbGgF
                  80 XS 1100 SG
                  81 XS 1100LH/SH DARKHORSE
                  https://tinyurl.com/k6nzvtw
                  AKA; Don'e, UD, Unca Don'e
                  • donebysunday
                    • Oct 2012
                    • 1737
                    • New Berlin, Wi.
                    #39
                    Originally posted by GLoweVA
                    I've been going at it for about a month now and a few things I've noticed.
                    1. My petcocks seem to be a bit smoother now.
                    2. My throttle response is a bit better
                    3. Once warmed up, it idles a bit smoother too.
                    Haven't notice much of an improvement in MPGs but that could be me too much on the throttle.
                    I've got to get my shims replaced and open up the valve clearances some, that might bring my compression up some and improve my MPGs some more.
                    I added 4 oz. of Merc 2 stroke oil and 4 oz. acetone full tank of non-ethanol 93, put 31 mi. on and filled up, about the same mpg. 28-29 maybe a bit more HP., maybe ?
                    76 XS650 C ROADSTER
                    80 XS 1100 SG
                    • latexeses
                      • Jun 2008
                      • 1491
                      • California
                      #40
                      When this first popped up here I tried the Acetone in the gas of my 85 Toyota that has about 190,000 on the odometer. I did a bit of driving around and headed for home. It sat there for three or four days and I sort of forgot about it.
                      A lot of things were happening and I wasn't even thinking about it the next time I took off in the PU. I was clear across town when I realized the truck felt like it had "smoother" power if that makes sense. I paid attention to how it felt for a bit and then remembered the Acetone. The best way I can describe it would be that it felt like it had smoother acceleration and it felt like a bit more power. Which I suppose is the same thing.
                      I didn't pay much attention to it after that. You get used to how something runs pretty quickly. I guess that it made a big enough difference to notice after have been behind the wheel for as long as I've the truck.
                      I was interested in the claims that the 2 stroke oil lowered emissions when going through a smog test. I am wondering how putting "oil" into a emissions system would make it burn cleaner.
                      Maybe there is someone here who is licensed to do emissions tests that could shed some light on the subject.
                      • CaptonZap
                        • Jun 2010
                        • 1748
                        • Denver
                        #41
                        I don't know about the emission testing, and I wonder if the praise was delivered after they had used the acetone for a few tanks and then went for the test, and the acetone had done it's magic. (Testimonials are always suspect without complete details.)
                        Anyway, for anyone who might be interested in the use of acetone, http://www.pureenergysystems.com/new...00069_Acetone/
                        Unfortunately, the price of acetone has gone up along with the price of gas and beer, and cannot be bought cheaply.
                        Also, remember that acetone will soften a lot of plastics and rubber compounds, so think about what is inside your fuel system. (petcocks, hoses, etc)
                        In the small amount called for, it might not be a problem for a tank or two, after which you go back to straight gas. Anybody want to be a guinea pig, and let us know how it works out after a summers use?
                        CZ
                        • CaptonZap
                          • Jun 2010
                          • 1748
                          • Denver
                          #42
                          Here is another site that touts the use of acetone, as well as other thinners.
                          Your mileage may vary, pun intended.
                          CZ
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            #43
                            Well, I just poured an ounce into my full tank.
                            I'm game!
                            79F
                            "Excelsior"
                            Honda gl1100 handlebar
                            Vetter IV fairing with speaker system
                            OE headers,Jardine slipons
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            Oe hardbags and luggage rack
                            TC fuse block
                            K&n filter with oe airbox
                            Raptor 660 Acct
                              • 3273
                              Been running the two stroke TCW-3 in my bikes for over a year now. No discernible difference honestly in mpg, driveability.
                              But I have to believe the therapeutic benefits of coating the inside of the fuel system has to be beneficial in staving off E3 (Evil Ethanol Effects).
                              ZRX1200
                              Seca 750
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                #45
                                It's the prime reason I did this
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
