How can you test the reed switch in the speedo to make sure its good?
Flasher cancelling unit
1980 XS 1100SG
Dyna 3 Ohm Hi Output Coils
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCT -
1980 XS 1100SG
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCTComment
An old post by ELDR about this may help...
Check out Post #33:
Former owner, but I have NO PARTS LEFT!Comment
By a long shot, I don't know as much about electronics as Randy does. But I really don't think that circuit is capable of counting pulses from the reed switch.'81 XS1100 SH
Sep. 12th 2015
RIPComment
Learned some thing new this morning! Yay!
And I was so wrong!
I thought the O.E.M. flasher was just a fancy, oversized and overpriced thermal make/break type of flasher with a capacitor molded into one end for the self-canceler time/distance calculator circuits.
If I read the reference thread correctly, and there's a good possibility I did not! I think ELDR was saying that the self-cancel feature draws a little less than one amp even when the turn signals are off .-- Scott
โฌ
โฌComment
โฌ
โฌComment
But there's more going on here than just that. When I still had the hitch/trailer on the '78, I swapped to a 'up-to-8-lamps' electronic flasher. According to what I can find, this supposedly has more-or-less the same internal circuitry as the OEM unit. It was three wire, but I did have to swap two wires at the plug (yellow/green, brown/white) to get the lights to flash, which leads me to think that the Yamaha flasher is non-standard in other ways.
But ELDR also hints that this mod doesn't really change the turn signal load as per his referring to the fact that it's the running lights that are a constant drain and the turns are only intermittent. So I suspect that what he's done is 'shift' the load into the flasher by adjusting the internal values, so that the load the canceller 'sees' is still the same for a net power gain of zero when using the signals, but allowing you to use dual-element LEDs for running lights.
I may be wrong on this, but if this isn't the case, then any three-wire flasher should work and we all know that's not true. Admittedly, my electronics knowledge doesn't stretch this far without a lot of head-scratching...Fast, Cheap, Reliable... Pick any two
It doesn't count the pulses, the cancel unit does, it just reacts to the cancel unit telling it to shut off the turn signals. The stock flasher unit doesn't count the pulses from the reed switch either, it just disables when the auto cancel unit applies 12v to the 3rd pin of the flasher. Being an electronics guy myself, I understood the circuit right away. That circuit should work just fine, either with the transistor or the relay, but the relay is something far easier for the layman to install, so that's what I'm going to attempt and write up (assuming I prove it works). The transistor is what I'd use if I was building units to sell, it being solid state and all. Seeing that circuit, I can also see how both failure modes of the auto canceler happen. One is that the 12v never gets applied, and the other is that 12v is always applied so they cancel as soon as the lever is released (this assumed no wiring problems of course). I'll tell you what though, I'll let you know how it works after I try it this weekend (I figure it will take about 20 minutes to do the mod, even with taking pictures along the way).Cy
Well, for whatever reason he's not showing the reed switch part of the canceller circuit; remember, it's the canceller that reads that, not the flasher.
I may be wrong on this, but if this isn't the case, then any three-wire flasher should work and we all know that's not true. Admittedly, my electronics knowledge doesn't stretch this far without a lot of head-scratching...Cy
If you can come up with a way to build a flasher that will flash 'other' loads and retain the cancelling, it'd be great...Fast, Cheap, Reliable... Pick any two
