trike
The hypoid gears in auto rearends are helically cut, there is virtually no friction between the ring and pinion gears, they are constantly in mesh, and cut so as not to ride up as power is applied. Running them in reverse will cause friction, and the gears will tend to pull apart. The whine is there because the gears are rubbing against each other and pushing themselves apart. The only way to overcome this is to find gears that were meant to run in the opposite direction, and to the best of my knowledge, these do not exist. However, any shaft drive cycle with the drive on the right hand side will have the proper shaft rotation. I think all Hondas, including goldwings and the 500 and 650 silverwings drive on that side. If you could find an industrial 90 degree differential with a ratio of 2.5 up to 3.5 to one meant to turn in the right direction. you could mount that rigidly to the frame and have axles of the front drive type with individual suspension. Complicated. Your best bet would be to trade your XS (horrible idea) for a gold or silverwing, or other shaft bike with the drive on the right hand side. I don't know just how much whine there is in a backward running rear end, or how fast it would wear. I do know it has been done. There is a guy in England that did it. Maybe T C could help you find the old post from the early XS.com that tells how to make a reversing unit. Hate to rain on your parade, but facts are facts.
, but at least you'd have matching wheels...
