Think Tank
  • Joab
    • Aug 2010
    • 472
    • Ozark, Alabama
    Ok, this seems like a bit of an uncomfortable thread for a new person like myself to be posting in, but...what is the shim library?
    Joab
    "If nothing else, it will be interesting..."
    ______________________________________________
    1979 XS1100SF
    1972 XS2 650
    Ozark, Alabama
    • b.walker5
      • Feb 2009
      • 1745
      • Invercargill, New Zealand
      Check here.. http://www.xs11.com/forum/showthread.php?t=29346
      Sorry, just re-read your post. The shim library is a collection of valve bucket shims held by the group for swap when needed for engine tuning.
        Hey Joab,
        As Brian stated, its a collection of different sized shims that fit the valve buckets in our bikes. As you may know, it is recommended that you periodically check the valve clearance. If it is out of spec, you change out shims to bring it back into spec.
        Shims can be fairly pricey or even tough to find locally, so there has been a "library" created. If you need a different size shim, you contact the current "librarian" or keeper of the shims. If you send them your shims and a postage paid envelope, you get the sizes you need in return. This is, of course, dependent upon the library containing the sizes you need.
          #34
          If the library does not have it you can try eBay, local dealers, or the Ford sho motor also uses the same 29mm ships. There are some places online the sell them as well for a reasonable price.
            #35
            I found a local small bike shop that has them and sells me shims for $2 a piece, thats me keeping my old ones. So, they can be had. Also, IIRC, Suzuki has some models using the 29 MM shims as well.
              #36
              Wow the local dealer here was tryin to charge me 25 bucks a shim, and then I said F-that
              • 79XS11F
                • 3563
                • Ottawa, Ont. Canada
                #37
                WOW, is that installed?
                Rob
                KEEP THE RUBBER SIDE DOWN
                1978 XS1100E Modified
                1978 XS500E
                1979 XS1100F Restored
                1981 Suzuki GS1100
                1983 Suzuki GS750S Katana
                1983 Honda CB900 Custom
                  #38
                  Rob
                  Unfortunately not. That was shin TRADE alone. Yes everyone hates that place. There are a lot of hardley dealers here but not so many for everything else. Supply and demand, it suck for everyone but the dealer.
                  • prometheus578
                    XS-XJ Super Guru (RESIGNED)
                    • Aug 2004
                    • 4012
                    • Olympia , Wa.
                    #39
                    If I may...
                    The 29mm shims were mostly used for Yamaha, though there are many Kawasaki applications.
                    Suzuki used a shim size of 29.5mm. (Mostly for the GS series bikes)
                    These shims will not work. I recommend, that if you find a shop that will swap out shims for you, measure the outside dia. to ensure you've gotten the right size before you drive all the way home and try to install them.
                      • 8793
                      Also a good source for shims at a reasonable price.....
                      07 Triumph Tiger 1050
                      • Joab
                        • Aug 2010
                        • 472
                        • Ozark, Alabama
                        #41
                        And now I know! Ugh...well, looks like I'll have to try out one of these options soon, I have a feeling my first winter back in the south (originally from Minnesota) will not be a riding one. I fix one issue, to discover two more! But that is what keeps life interesting, right?
                        Joab
                        1979 XS1100SF
                        1972 XS2 650
                        Ozark, Alabama
                        • MrOzz
                          • Aug 2008
                          • 782
                          • Massachusetts
                          #42
                          I was able to get shims from a local BMW Motorcycle dealer. $4.00 each with no trade in of my old ones.
                          1980 XS 1100SG
                          Dyna 3 Ohm Hi Output Coils
                          Pod Filters
                          DynoJet Kit
                          T.C.'s Fuse Block
                          V-Max Auto CCT
                          • cywelchjr
                            XS-XJ Super Guru(Deceased)
                            • 4450
                            • Sacramento, CA
                            #43
                            I think you might be able to get shims from your local Ford dealer as I believe that at least some of the SHO Taurus's shared the same shims in their valve train.
                              As Prom stated, majority of Kawy's use 29mm shims. One of my local dealers here, who employees a mechanic whom I've known for years through the bike thing re-shimmed my XS Venturer valves and was very reasonable at $40. Heck, the valve cover gasket and cam-end plugs OEM cost me that. IIRC, it had three tight exhaust and one tight intake which on the 81 clearances are set at the higher end of the specs.
                                #45
                                If you are desperate
                                and as a last resort you can use a magnetic plate surface grinder to reduce a shim's thickness by the same amount that's needed to restore the clearance back into spec.
