new to BS34 Carbs & putting them on a my car
  • SFerinTEXAS
    • Jun 2006
    • 877
    Vents
    This guy did it. http://www.youtube.com/watch?v=gHEgdZLj3KI
    79SF
    XJ11
    78E
    • jonuts
      • Mar 2010
      • 11
      • HOUTX
      Originally posted by kirmit77
      i would love to see that set up!!! how it coming??
      I live north of houston and if you need some jets i have some
      good to hear another local member is nearby. i appreciate the offer. hopefully the car will be running soon again. i'd rather run these carbs if i can than the weber 32/36 i have on there from a bmw 2002.
      Originally posted by DGXSER
      As I stated, I am only really familiar with the XS11 version and these are not the identical beast, but I would suspect that nipple in purple will be the beast.
      i'll give it a go.
      Hi jonuts,
      first, kudos on your endeavor and hopefully the list's carb wizards can help you get yours sorted out.
      But here am I wishing there was only one carb on my XS11 so I didn't have to try balancing four of the bastards.
      Takes all sorts, eh?
      i'm going to make sure to pay attention. thanks for the kudos.
      Originally posted by SFerinTEXAS
      very cool. very cool. i messaged CeliRob for some pointers. hopefully he'll respond.
      AUTOSPORTLABS
      NonStop Tuning
      www.86garage.com
      "Poverty is not a virtue."
      • oseaghdha
        • Aug 2006
        • 1075
        • N43.02.5,W88.14.2
        If you pull the "purple" caps, you are going to have a vacuum leak.
        That's not what you need.
        XS1100SF
        XS1100F
        • 81xsproject
          • 3185
          • Fortuna, CA
          If I were going to run 70's BS34's on something with a fuel pump, I would definitely upgrade the float valves to Viton tipped ones. If you do a search for Viton, you will find the thread I wrote about what part to order for the better float valves.
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
            • 7807
            The fuel system has a "T" after the regulator. Strait through goes back to the tank, and the leg on the "T" goes to the carb inlet. We put two on the Datsun, one for each carb. As you have a single inlet, you should only need one.
            Do NOT forget about the brace between the carbs. I would get an aluminum angle at ACE HARDWARE and fit it as a single brace across the bottom. If it's NOT a single brace, the carbs WILL move and cause running problems. We had that with just two carbs!
            BTW, those MAY be off a KZ from looking at them.
            • jonuts
              • Mar 2010
              • 11
              • HOUTX
              good deal. i'll T in after the reg. with one 1 to the single inlet and the other to the fuel return.
              yeah, i have the pairs braced separately but have another single brace underneath bracing 2&3 together.
              81xsproject, the Z1 site showed the float needle assemblies as being temp. out of stock but i did find this as well as a 2010 Sudco price list in .xls format with them at 8.82ea. They're Keyster parts made in japan. The .pdf catalog shows an image resembling the one with the black seal and flat screen. is that the right one?
              this is the image from the Sudco catalog:
              AUTOSPORTLABS
              NonStop Tuning
              www.86garage.com
              • 81xsproject
                • 3185
                • Fortuna, CA
                That does look correct, however, I would use the cross reference list on the z1e listing to make sure.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                  • 7807
                  I saw that, and that is the reason I mentioned a SINGLE brace. With the carbs how you have them, they WILL move, and throw the sync off. Flat stock, like you are using, WILL twist and bend. Angle is a much STIFFER shape, and will NOT bend or twist as easily. I know this from experience on the Datsun.....
                  • jonuts
                    • Mar 2010
                    • 11
                    • HOUTX
                    i appreciate it. i agree the angle will be stronger. i'll address that soon here.
                    AUTOSPORTLABS
                    NonStop Tuning
                    www.86garage.com
                    • jonuts
                      • Mar 2010
                      • 11
                      • HOUTX
                      well, after unplugging the 2 ports and pulling the upper hoses from between the carbs, she fires right up and idles with no fuel pouring out of the front of the carbs. still looks like too much fuel as i'm getting seepage on some of the hoses. i'll be picking up the low pressure fpr today and T-ing in a return fuel.
                      like below:
                      AUTOSPORTLABS
                      NonStop Tuning
                      www.86garage.com
                      • jonuts
                        • Mar 2010
                        • 11
                        • HOUTX
                        alright, ran it with the above fuel routing and the motor did not like it one bit. it ran better unregulated with just the single fuel feed.
                        i'll just put it back to the way it was but keep the regulator in place and go from there.
                        i'm going to have to fab up that angle for all 4 DiverRay. 3 & 4 popped off when trying out the new fuel routing and had a back fire.
                        AUTOSPORTLABS
                        NonStop Tuning
                        www.86garage.com
                          I'm thinking that the return line after the regulator is not allowing enough fuel to get to the carbs. There would have to be some restriction in that return line to allow some pressure to the carbs so they can get fuel. If it's an open line it's just a dump of fuel back to the tank.
                          • jonuts
                            • Mar 2010
                            • 11
                            • HOUTX
                            yeah, i was surmising the same thing.
                            i'm just going to put it back to the way it was but with the regulator in place. it should be closer to kosher.
                            AUTOSPORTLABS
                            NonStop Tuning
                            www.86garage.com
                              • 7807
                              I'll try and use the keyboard to show you the way to run the fuel lines.
                              Pump ,,,,,,,, P.R.,,,,,,,,,,Carbs ,,,,return
                              0-----------0------------T--------|
                              blank space blank space bl|ank spac|e
                              blank space blank space blank blank | To tank
                              read between the blank spaces!!
                              If this stays together, you can see the return line is AFTER the "T" for the carbs. That is the ONLY way it will work properly.
                              • jonuts
                                • Mar 2010
                                • 11
                                • HOUTX
                                by the looks of your routing suggestion, i'll need to introduce a T into the fuel line between a pair of the carbs for the return. hmmm.
                                AUTOSPORTLABS
                                NonStop Tuning
                                www.86garage.com
