VIN Number Reference??
  • Mathh
    • Nov 2006
    • 697
    • Beek, Netherlands
    Vin is on the right side of the headstock. Difficult to see on the pics how the rear brake lever is operating. If it is pivoting through a black framemounted tube sticking through a hole in the alu plate it is a Special SF frame, if it is pivoting in the alu plate itself it must be a standard frame (I guess). All the rest seems to be SF except for the Standard clocks. Even looks like a 16 inch rear wheel to me (SF)
    MV Agusta Brutale 910R '06.
    Yamaha MT-09 Tracer '15 grey.
    • equinox1216
      • Mar 2009
      • 54
      • Lebanon, Oregon
      Headstock??
      Sorry for my lack of knowledge in this respect but What/where exactly is the Headstock?
      As for the rear brake lever, it attaches to a gear coming out of a plate. I guess I would need to remove the pedal to see what's around that gear.
      And what's "the Standard Clocks"??
      Thanks for the help.
      • 1979 XS1100SF Special Hybrid
      In the end, it's not the years in your life that count. It's the life in your years.
      • equinox1216
        • Mar 2009
        • 54
        • Lebanon, Oregon
        Got the frame VIN
        VIN on the FRAME is 2H7-000761
          Spandard??
          I think by "clocks" he meant the gauges: square for standards and round for specials.
          The 2H7 is a standard frame.
          3H3 is f'shizzle a special motor.
          Frankenbike???! Naw. I wouldn't call your bike that. It looks well done no matter what pieces/parts were from which model or year.
          All that matters is that ya gotta hang on tight when twisting that throttle grip.
          • Mathh
            • Nov 2006
            • 697
            • Beek, Netherlands
            yup!
            • xs11lover
              • 1433
              • Montoursville Pa
              Ok then, that clears it all up. The info is listed on the FAQ tab, then click #4 Serial numbers/ Mod.....
              The frame and engine number should match.
              It looks like you have a 79sf xs11 special motor ( and just about everything else) With a 78 xs11 e standard frame (and gauges)
              The tail light looks like it's from a Maxim?
              79 XS11 Special (Lazarus)
              79 DT 100
                Hi Equinox,
                now you found the frame # you know what the tube the steering turns in is called, eh?
                And clocks is standard slang for gauges. Note that your Special tank leaves the factory with a thermistor type fuel gauge sender in it that won't work with the fuel gauge in the Standard's rectangular tachometer.
                • bobber
                  • Dec 2008
                  • 82
                  • los olivos. ca
                  bike years
                  just wondering what the earlyist frame # are still around. [vin].that people still have or ride.
                  for each model. did any one make a list.
                  78 1100e 2h7002440 thats mine.california.
                  i mean complete bikes. just thought,maybe someone has the 1st bike of each model.that would be great if they are still around.
                  1978e. special forks.she's a frankinstien.a bit of this a bit of that.its a monster
