VIN Number Reference??
  • equinox1216
    • Mar 2009
    • 54
    • Lebanon, Oregon
    I was under the impression that somewhere on this forum there was a VIN number reference... so that one might determine exactly what a bike was by matching the VIN against a list... or something.
    I just spent a good long time searching various terms and came up with nothing. Just a few hints from some posts and replies. I still don't know exactly what I have.
    Is there such a list??
    Thanks in advance.
    • 1979 XS1100SF Special Hybrid
    In the end, it's not the years in your life that count. It's the life in your years.
    • 8930
    Should be in this thread....
    • equinox1216
      • Mar 2009
      • 54
      • Lebanon, Oregon
      Confusing...
      Thanks for your reply...
      Going by the list of Vin prefixes, I am left with a puzzle.
      1978 XS1100E 2H7-000101 Macho Maroon
      1979 XS1100F 2H7-020101 Magenta Red, Indigo Blue
      Mine starts with 2H7 which is listed as either a 78 or 79, if I'm reading this right.
      And an XS1100 E or F. Which I don't get at all.
      So this isnt helping a bit.
      I THINK it's a 78 XS1100 SF but that is merely because of many of the parts of the bike. Like the front forks attaching behind the axle, the round instrument guages and head light, the teardrop tank.
      I cant even find out what the SF means in xs1100SF.
      Maybe I've been at this too long for today after working 14 hrs lol
      Maybe a picture would help.
        • 8930
        Looks like a 79SF Special. Check the VIN on the motor and the frame neck, someone could have "switched" things. S means Special and F is the year-79.
        • rpgoerlich
          • Dec 2007
          • 643
          • Katy, Tx
          There was only a standard in 78.
          Richard
          • equinox1216
            • Mar 2009
            • 54
            • Lebanon, Oregon
            re: Check the VIN on the motor and the frame neck...
            Okay I will do that when I get back to the house this weekend.
            Thanks for clearing up the SF.
            ...yeah looking at the 1978 Standard, I can't see much resemblence. and doing a google image search for the various models, I have to agree with you.. looks like a 79SF Special.
              • 7830
              IT COULD be a "frankenbike". The photo shows TOO MUCH FRAME in front of the fuel tank. Some PO may have hit something, and put the special front end and tank on a standard. 2H7 IS ONLY A STANDARD, the Specials had a different serial number.
              • equinox1216
                • Mar 2009
                • 54
                • Lebanon, Oregon
                I may never know the real answer...
                .....yes indeed... so many possibilities. I will start with the frame/engine number this weekend and go from there.
                Thanks
                  Thanks
                  Hi Equinox,
                  you didn't say, is the 2H7 prefix on the engine or on the frame or on both?
                  If the frame number starts with 2H7 the bike left the factory as a Standard.
                  If the complete frame and engine numbers are not the same, the engine (or at least, the crankcase) is a transplant.
                  Like Diver Ray sez, it could well be a Frankenbike.
                  Which is not necessarily a bad thing.
                  As most of the parts on XS11s swap between years and models like Lego,
                  if you don't like the way a particular part looks, put on one you do like.
                  • equinox1216
                    • Mar 2009
                    • 54
                    • Lebanon, Oregon
                    VIN location
                    Hi Equinox,
                    It was on the TITLE. I haven't looked on the bike yet. I will do that this weekend when I get home.
                    • xs11lover
                      • 1433
                      • Montoursville Pa
                      Sure looks like a 79 xs1100 sf special to me. I don't see anything that would make me think it's another one. It has the plastic cowl over the front of the frame (in front of the tank). Standards don't have them. 79 special forks, seat, grab bar, fender, tail light,tank, bars, exhaust.
                      ohhhhhhhh but the top of that side cover looks too flat to be a special........maybe it is a standard frame. Need a new pic of the side cover.
                      79 XS11 Special (Lazarus)
                      79 DT 100
                      • equinox1216
                        • Mar 2009
                        • 54
                        • Lebanon, Oregon
                        More like a 79SF Special everyday...
                        Well I was just thinking I need to take some better pics of this thing. So I will be doing that this weekend for sure...
                        Thanks for your help.
                        • equinox1216
                          • Mar 2009
                          • 54
                          • Lebanon, Oregon
                          By the way...
                          I hadn't mentioned before that all the YAMAHA emblems had been removed and a custom green paint laid down on everything at some point (by a previous owner). The right side cover is the only one with the bike (which I understand is often the case due to the locking mechanism being broken by newbies or something) and there is no emblem on it, nor is there any sign that there ever WAS an emblem on it. (i.e. no holes, etc). It may well not be for this bike.
                            If you compare the serial number (VIN) on the engine AND the frame to that list, that will give you the "official" model. I think what may be confusing you is:
                            Notice that, after the 2H7, the '78 (E) has 000, then 3 numbers. It may also have just 00, then 4 numbers, depending on how high the serial numbers went that year...
                            The '79 (F) has only a single 0, then 5 numbers, starting with a 2. That is the difference between the 2 sets of VIN numbers.
                            Of course, there is also the Canadian version:
                            1979 XS1100F 2H7-110101 Indigo Blue, Magenta Red
                            That VIN starts with 2H7-11.
                            • equinox1216
                              • Mar 2009
                              • 54
                              • Lebanon, Oregon
                              finally the weekend... now for an update:
                              I brought the bike out into the sun and took a series of pictures from all angles. I will post them here.
                              Also, I found the VIN on the ENGINE, which does NOT match the VIN on the TITLE. Can someone tell me where to find the VIN on the FRAME?
                              Here is the VIN on the ENGINE:
                              3H3-004478
                              Now, going by the list from that earlier thread, should I assume that at the very least the engine is from a 1979 SF?
                              (( the list ))
                              Serial Number & Model Identification
                              US Models:
                              Year
                              Model
                              Serial #
                              Color(s)
                              1979 XS1100SF 3H3-000101 Carmine Red, Black Gold
                              1980 XS1100G 3H5-000101 Diamond Silver, New Ruby Red
                              1980 XS1100SG 3J6-000101 Black Red, New Ruby Red
                              1980 XS1100LG 4H3-000101 New Yamaha Black
                              1981 XS1100H 4R1-000101 Indigo Blue
                              1981 XS1100SH 4R0-000101 Black Blue, Cardinal Red
                              1981 XS1100LH 4W1-000001 New Yamaha Black
                              1982 XJ1100J 10M-000101 New Yamaha Black, New Ruby Red
                              Now pics....
