Yamaha paint codes
  • newc4
    • 597
    • Vienna VA
    If found that the burgandy color used on the early 90s Caravans is a close match to the 78E Macho Maroon. My tanks, cowling and side covers are painted that color. My seat trim is original and there's only a slight difference.
    I though someone on the list had already researched this.
    Darrell
    78E
    80G project
    06FJR
    • Dusterman
      • May 2011
      • 2
      • Spring Hope, NC.
      I found a matching color.
      You probably won't believe it but the: "DARK TOREADOR RED" from Ford, late 1990's matches very well and is inexpensive too. You can still get touch up bottles and spray cans at the auto parts store.
      I tried it on a test piece of metal and found it difficult to tell the difference.
      I hope this helps.
      • jwhughes3
        • 2798
        • Home of the Alamo
        http://www.colorrite.com/
        ColorRite is the leading provider of paint for your motorcycle, personal watercraft, snowmobile, ATV, or outboard engine. Known for a spot-on-match for your v
        Motorcycle Paint Codes...but only for 1986 and newer cycles - sorry I just thought to recheck - I used it to find paint colors for an R1 for someone...
        Darn.....
        John
        '81 XS1100H - "Enterprise"
        • mack
          • 2411
          • Ontario, Canada
          paint
          When I was doing Hermes, I wanted it back to the original. What I did was take the tank and side cover emblems off and had the unexposed paint scanned. I was worried about the amount of gold fleck in the black to be the same. I should have had the formula written down. I"ll see if I can track it down and post it. Not sure how I'm going to tackle the LH yet. There was a clear decal on the inside face of the exhaust pipe. Under it the paint was pristene so that,s the balck I'm going with. The gold is still causing me heartburn. Has anyone got a link for the nebula gold?
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
            The pipes are not painted - they are black chrome. Matching the color of the pipes won't do any good for the paint codes. The paint code for New Yamaha Black is in post #10 of this thread. That's the correct color for the MNS paint.
            • mack
              • 2411
              • Ontario, Canada
              Black chrome
              Yep, they are black chrome, however I'm supporting 7 on my pension. Black chrome is out of my ballpark. Black ceramic paint is what they're going to get. Color and gloss same as what was under the sticker.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
              • BowlingSS
                • Apr 2015
                • 398
                • Lawrenceville, GA.
                How many cans of spray paint is needed for the special tank. $33 a can is high for the Yamaha 006g but I want to order some.
                Thanks.
                Bill
                Jardine Spaghetti with Harley Mufflers
                  Thanks.
                  Bill
                  Hi Bill,
                  if you mean a can of paint for your own spray gun the smallest can they sell is the one pint size.
                  I painted my XS11SG's Standard tank, both side panels AND a sidecar with that amount of paint. Note that I used a 2-part paint so add another pint of extender/hardener to the pigment amount.
                  If you are talking custom-color rattlecans, look at using a Preval unit instead
                  • BowlingSS
                    • Apr 2015
                    • 398
                    Hi Bill,
                    Great idea. I have a couple of Preval units that I bought long time ago. I hope they still have pressure. I wonder how long they last on the shelf?
                    Bill
