140 MPG Honda (bio-diesel) Rebel
  • Bartolucci
    • Nov 2009
    • 58
    • Rochester, New York
    http://www.specmotors.com/dean.html
    10 horsepower. I wonder how fast it will go?
    Tony A. Bartolucci
    Present Ride: 1982 XS400LJ Custom
    Former Rides: 1981 XS1100LH
    1975 Kawasaki 100 2 Stroke Enduro
    1975 Honda 750F
    Current Cool Cage: 1966 Chevy Impala 396
    Probably not very....
    And a pull start??!!!
    '78E original owner
    • xs11jack
      HALF GURU
      • Nov 2002
      • 606
      • O'Fallon, Mo.
      With 10 hp.
      He ain't gonna set any speed records. He probably has to sit on that thing 10 or 12 hours to go 140 miles. A bicycle could get there faster. And a single cylinder must vibrate like a jack hammer. It's basically a novelty.
      J.D."Jack" Smith
      1980G&S "Halfbreed"
      1978E straight job
      "We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
      Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
        • 7738
        The ONE thing you forget about the the torque diesel will develop. If it's geared properly, it will probably hit 65mph easily! Remember, the early VW beetle was only 36HP!
        • lakecountrydave
          • Aug 2007
          • 384
          • Phoenix, AZ
          DiverRay is right. A diesel engine produces lots of torque not hp. For example the Chevy Duramax diesel makes 365hp @ 3200 rpm and 660 ft lbs of torque @ 1600rpm. Plus, the Rebel is an beginner level 250cc bike that is not really made for highway use (although it is highway legal). I believe that they are used in a lot of the rider training courses. The Rebel only produces 16.1HP, 12.4ft/lbs from the factory (1996 #s).
          Dave
          1979 XS1100SF Special
          • BossMaverick
            • Aug 2008
            • 130
            • Montana
            The downside to deisel is that the redline is lower then a gas engine. I imagine that bikes pulls good for a Rebel off the line but doesn't have the top speed like a normal Rebel, unless his transmission is that good. The 250cc class bikes really depend on having a good gear ratios.
            None the less, I like it. It's way cooler then a moped.
            1980 XS1100 Standard "Touring"
            Fairing, Trunk, and Bags
            850 FD
            Fork Brace
            Progressive Front Springs
            Engine Guards w/Foot Pegs
            Oil Cooler
            Throttle Lock
            Uni Air Filter in Airbox
            2009 Suzuki Bandit 1250S ABS
