Rick and Ray, thanks for the encouraging suggestions. Been working at it alot of today, but feeling abit like I am polishing a turd because of the low compression. Reading experienced and smart fellows like you feel it should come back gives me alot of hope.
Carbs are almost back together now. Waiting on new pilot air jets to finish them off. I think I know another reason why the carbs were jetted so rich, the floats were set at the 25-26mm level on the newer style carbs. So, floats are set to 23 mm, 42.5 pilot jets 110 mains across the board, waiting for my 185 pilot air jets to come in. I also found a hole in the diaphram to no 1 carb and patched it up with RTV silicone. Looks like it rubs on a rough spot in the JB weld someone used to patch an uh-oh in the diaphram area of the carb. So I shaved the JB down with a sharp chisel to make it smooth as well.
Also cleaned the front MC out and blew out all the lines with brake cleaning fluid. So the front stoppers are almost ready to go to work. The front pads are bit on the slim side, may wait till spring to buy new ones though. Or at least until I complete my shopping list for PNM parts.
