Hey Wlsmoku,
If you have already taken off the shift lever cover, and haven't found any circlips missing from the shift pawl mechanism...there are 2 on that side, one next to the engine case, and one on the outside of the shift pawl lever.
Then, that circlip is from the OTHER end of the shift fork shaft...where the oil pump idler gear is mounted to the end of it. You'll want to inspect the shaft closely to ensure that the little dowel pin that's supposed to be near the idler gear end is still intact.
I, too, can't see/make out the other part in the pan?
