what is the highest power pellet gun?
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    i can't pump, it can't leak, and has to be deployed on a moments notice, but a real gun in going jail time in the city...
    would any have enough range to require a scope or laser?
    deep flesh penetration would be prefered
    short of a 22 calibre, rifle, what type of gun/ rifle will put a hurtin on nightime racoon, skunks and possums,
    and do they learn a lesson, or would they come back for more?
    comments?
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • blue giant
    • Aug 2007
    • 880
    • Ontario, Canada
    I have a Beeman with a scope. Break barrel loading, doesn't require pumping and fires pellets at just under 500 feet/second requiring no license or permits.
    HTH
    Paul
    Paul
    1983 XJ1100 Maxim
    1979 XS1100 Standard
    1980 XS1100 Special
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      HTH
      Paul
      1round at a time? can i leave it in there primed? will it screw up the cocking and spring?
      they say they have a 750 fpi unit is that right?
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • Toolmaker Tim
        • 671
        • South Bend, Indiana
        Air Rifle
        Go to Cabelas' website, they have RWS, Beeman, Gamo, and a lot of others. I've been told there are air rifles powerful enough to kill a fully grown Bison. The guy that told me about that is deeply into airguns.
        1979XS1100SF
        K&N's and drilled airbox
        Jardine 4in1
        Dunlop Elite 3's
        JBM slide diaphragms
        142.5 main jets
        45 pilot jets
        T.C.'s fusebox & SOFA
        750/850 FD mod.
        XV 920 Needle Mod.
        Venture Cam Chain Tensioner
        • blue giant
          • Aug 2007
          • 880
          • Ontario, Canada
          Yes one round at a time. I believe you can, I have for short periods of time with no noticeable loss in power. They probably do but you will likely need a permit or license for it. I'm not sure how your laws differ from ours. I have no problem killing squirrels with mine. I have never tried to shoot anything any bigger but I'm sure a racoon or skunk would get the message loud and clear!
          Paul
          Paul
          1983 XJ1100 Maxim
          1980 XS1100 Special
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            Paul
            how far away can i be to kill a rat, and what is the best place to shoot em at? the head or torso?
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • blue giant
              • Aug 2007
              • 880
              • Ontario, Canada
              I've been as far as 50 feet. Head shot is the best but a torso shot will take them out too. I've killed more tin cans with mine than squirrels or rats.
              Paul
              Paul
              1983 XJ1100 Maxim
              1980 XS1100 Special
              • mason79
                • Mar 2006
                • 1359
                • los angeles, ca
                Paul
                with the head shot, so they run away and die later? or die right there?
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                • red bandit
                  • 955
                  • central michigan
                  If you shoot an animal in the guts/intestines they will run/walk/crawl away and then die and you don't have to deal w/ the carcass. Shoot them in the brain they die on the spot. Heart/lungs they don't go far and die.
                  The only lesson coons/opossums and such learn is to avoid humans. If you don't want them around you have to kill them.
                  Antifreeze works good. I've heard a bottle of aspirin dissolved in milk works good too.
                  79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
                  79 SF parts bike.
                  • wa407mpp
                    • Jul 2007
                    • 717
                    I have a RWS model 52, 1100 fps., but for most varmints I use a slingshot with marbles. With a little practise you can roll them pretty easily and they will run away so you don't have to drag them off, Of course after a few hits they can't be coaxed back even with the most tempting baits.
                    Fastmover
                    lion". SHL
                    78 XS1100e
                    • wa407mpp
                      • Jul 2007
                      • 717
                      Sorry! I got off the subject there. The RWS has a side cocking lever, just one easy to pull is all it takes.
                      Fastmover
                      lion". SHL
                      78 XS1100e
                      • mason79
                        • Mar 2006
                        • 1359
                        • los angeles, ca
                        will how much asprin? never heard of that, how much antifreeze do they drink and do they die right there?
                        History
                        85 Yamaha FJ 1100
                        79 yamaha xs1100f
                        03 honda cbr 600 f4
                        91 yamaha fzr 600
                        84 yamaha fj 1100
                        82 yamaha seca 750
                        87 yamaha fazer
                        86 yamaha maxim x
                        82 yamaha vision
                        78 yamaha rd 400
                        • mason79
                          • Mar 2006
                          • 1359
                          • los angeles, ca
                          i thought about a sling shot but man, kentucky windage must be hell....
                          btw that gun is a nice piece, 470 bucks yikes! can get a .357 mag for less that that...
                          History
                          85 Yamaha FJ 1100
                          79 yamaha xs1100f
                          03 honda cbr 600 f4
                          91 yamaha fzr 600
                          84 yamaha fj 1100
                          82 yamaha seca 750
                          87 yamaha fazer
                          86 yamaha maxim x
                          82 yamaha vision
                          78 yamaha rd 400
                          • latexeses
                            • Jun 2008
                            • 1491
                            • California
                            If you want to explore the limits of airguns take a look at
                            http://www.airgunsofarizona.com/.
                            You can have charged airguns that you won't believe...
                            I recently had a friend who took out a raccoon that was fighting to get into his apartment at 1:30 am. Used a .177 pellet. I had best not discuss the entire episode here but it was stone dead in one hit.
                            Be prepared to answer a bunch of questions if anyone sees or hears you shoot an air rifle inside most city limits. In many cities they are considered firearms. Airguns powerful enough to take small game are loud! If they are fast enough the pellet will be supersonic and there will be the unmistakable "crack" when fired.
                            Unless you have a need for a coonskin hat I advise my buyers to find the cheapest paintball gun you can find and keep paintballs in the fridge not the icebox (freezing will break them). They will be stiff and the racoons won't like them very much. They do remember where they were when they get smacked. If anyone complains, you have a leg to stand on.
                            Everything on hold...
                              Also not mentioned here.. and don't laugh.. but blow guns, with some practice, will take out anything you have mentioned. I got to where I could hit about a 2 inch group at @ 60-70 feet and sink the darts so deep into a thick telephone book, that it required pliars and some considerable tugging to get them out. Once you get good, they make a small, hard, sharp, plastic broadhead to attach to the darts. You can keep one ready at all times.. very quiet.. and very legal. They will generally pass completely through whatever you shoot in the torso.
                              If going the antifreeze route, for some reason, the animals prefer used antifreeze. I don't know what happens to it chemically, but I've never had any luck with new stuff. Be prepared for them to "Expire" right next to the container they were drinking it out of though. I would warn the neighbors of your intentions so they can keep any family pets from becoming an unintended target.
