Off Idle Stumble POLL
    Hey folks,
    PeteW asked me to get this thing posted, so here it is to the best of my understanding what he was wanting to ask!?
    17
    I have 78/79 carbs with Pods/Modded Airbox and DO have Off-idle Stumble
    11.76%
    2
    I have 78/79 carbs with Pods/Modded Airbox and DO NOT have Off-idle Stumble
    41.18%
    7
    I have 80/81 carbs with Pods/Modded Airbox and DO have Off-idle Stumble
    5.88%
    1
    I have 80/81 carbs with Pods/Modded Airbox and DO NOT have Off-idle Stumble
    41.18%
    7
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    Okaaay
    My airbox is stock and I have no stumbles
    Based on the fact this poll exists I assume my airbox should stay stock
    Ernie
    • AlanB
      • Oct 2006
      • 705
      • Scotland
      Hi TC,
      This poll is not really for me, is it? I have no stumbles, and the Dyno sheets read over 90bhp at the wheel......
      I don't see how it helps Pete, 'cos he doesn't have XS carbs either! ??
      AlanB
      If it ain't broke, modify it!
      • red bandit
        • 955
        • central michigan
        Modded air box, no stumbles with 79 xs carbs or zrx carbs.
        79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
        79 SF parts bike.
        • petejw
          • 2269
          • sydney australia
          hi guys
          thanx heaps TC,
          thats great,
          i still couldnt figure it out. :-)
          AlanB, vote with the 78/79 carbs, these are fitted with the fuel
          vent hoses.
          Im just curious if the stumble occures more so with vented carbs compared to the non vented carbs fitted with pod filters.
          my 81 had pods and i had no problems.
          ernie, if ur box is standard, im not 2 concerned about these,
          just carbs fitted with pods/air box mods.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • mro
            • 4276
            • Hayward, California
            Not XS carbs either ... and no stumbles
            mro
            • olebiker
              • Aug 2007
              • 692
              • Kingston ON
              MRO that one boot looks like it has some pretty good cracks in it.
              http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
              • petejw
                • 2269
                • sydney australia
                MRO, there nice carbs, 1st time ive seen em up close. :-)
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • psycoreefer
                  • Feb 2008
                  • 1557
                  • Minden, NV
                  I've got 78/79 carbs with stock air box and I do have an off idle stumble. Well its not really a stumble as much as a lack of power.
                  1979 xs1100 Special -
                  My Bike:
                  [link is broken]
                  • tiredoffixing
                    • Mar 2008
                    • 89
                    • Ohio
                    With alot of help from alot on this sight , I have no stumbles at all. Im running pods,4 into 1. If I tried it by myself I would still have it in the garage siting there
                    • mro
                      • 4276
                      Out sides are cracked. Never got around to prettying em up.
                      No leaks tho...
                      mro
                      • olebiker
                        • Aug 2007
                        • 692
                        • Kingston ON
                        Hard to tell in a pic how deep the cracks run.
                        • TADracer
                          • 1417
                          • Kenner, Louisiana USA
                          Pods, 4-1's and no stumble. Its all in the jetting and tuning.
                          Mike Giroir
                          79 XS-1100 Special
                          • The Lorax
                            • Jun 2005
                            • 1048
                            • Riverside, OH
                            I have '80 carbs, with pods. I guess I have a bit of a stumble, more like a lack of power. the bike runs good by and large, but doesn't have as much go as I would expect from a large bore I-4. prior to my XS, I rode a 400cc twin, fun, but not heavy enough for the highway and too small in the frame for my 6' 03" 240lb carcass. I know what I need to do, get the mixture set properly, and sync the carbs. The pod filters are not so much the cause of my issues as my desire to ride something that runs ok versus not riding it and fiddling around trying to get it perfect. the mixture is close...but not perfect. I've run both the stock 4 - 2 and a Jardine 4 -1, the stockhas less stumble (yes, i have a larger set of main jets for the 4 -1) the Jardine is better up top, while the stock is better down low, I also seem to be limited to 6500 - 7000 with the stock exhaust. with stock, I'm running 112.5 in 1 & 4, and 115 in 2 & 3. when running the Jardine, I run a set of jets I bought in a local bike shop, 136's in all four. I need to take the time to get everything dialed in, but I want to ride too much, not enough summer left, was late getting out of the gat this year as I thought I had significant carb issues and let it sit till july only to find out it was a bad pickup coil (checked that on a hunch after I did some reading here). Anyway, I'll get to it here in a few weeks, and I'll be ready to scream when the season comes next spring, but I'm riding all I can, while I can. guess i got off on a tangent...rambling as usual. I'm out fellas, have a nice day and ride safe
                            I am the Lorax, I speak for the Trees
                            '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
                            '79 XS1100 F R (IL Barrachino)
                            '00 Suzuki Intruder 1400 (La Soccola)
                            '77 KZ400s (La Putana)
                              • 6762
                              My '81 has pods/modded airbox and no off idle stumble.My '82 has the same setup and it also doesnt have an off idle stumble.The '82 does have some dead spots or its bogging down at highr RPMs but fine from off idle.
