I thought the brakes were ok until
+ More Options
Posts
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    Yay - Boo
    Got my lines in . I inquired about the banjos that swivel but never quite got an answer so ... I have all lines that each end is inline with the other and I'm having problems routing . I remember someone warning about this . Funny the line guy didnt seem too worried about this item . If I bend them to make the connections the lines are twisted and look weird . I am inquiring with the supplier as to remedies .
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • Rasputin
      • 3180
      • Lacombe, Alberta, Canada
      When I recieved my S/S lines from cyclebrakes.com they came with instructions on how to adjust them. You put something hard but pliable "like a ballpoint pen" in the ends and then with a slight pull applied you simply twist the ends. I will see if I still have the pics here and post them.
      2-79 XS1100 SF
      2-78 XS1100 E Best bike Ever
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        I wish
        Communication with the supplier has revealed that the ends on these lines are not adjustable . I may have to send them back and there may be a charge for the new ones not to mention shipping
        XJ1100K
        Avon rubber
        MikesXS black coils
        YICS Eliminator
        • olebiker
          • Aug 2007
          • 692
          • Kingston ON
          #34
          They gonna hit you with a restocking fee? I hate that sh*t.
          http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            #35
            more in the saga
            I got a second opinion from a mechanic that I trust and he says at least one of the lines is a no-go and two others because of their length might be twisted to work . Only one line is ok .
            I figure if I have to send one back I will send the iffy ones too .
            I have sent an email to the supplier and will see what he says .
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
            • stereomind
              • 109
              • Tulsa, OK
              #36
              man, if you can't get them with adjustable banjos, I'd ask for money back.. One of the reasons we got Galfer lines (cyclebrakes.com) is because their banjos swivel 360 degrees. I don't know if that's the reason they are more expensive, but that little bit of flexibility is worth it IMHO...
              '81 XS1100SH "Hound of Basketville" - new project
              '81 XS1100H Venturer
              '81 XJ750RH Seca
              • olebiker
                • Aug 2007
                • 692
                • Kingston ON
                #37
                Axel maybe ya better tell that one to pound salt. Buy them elsewhere.
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  #38
                  the saga continues
                  Hindsight may prove a better path but I will send these back for adjustment . In the return email no cost was mentioned . I told them I would be unhappy if I had to pay more . Shipping cost was bad enough . But if all ends well it will be another lesson learned .
                  Still quite a bit cheaper than the Galfers but if you want no- worry , colored lines with matching bolts and washers ,thats the way to go .
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  YICS Eliminator
                  • stereomind
                    • 109
                    • Tulsa, OK
                    #39
                    hey, if they adjust them for you at no cost, that's still a good deal. after all, it only has to be done once.
                    '81 XJ750RH Seca
                    • GARTHXS
                      • Nov 2007
                      • 1631
                      • Seattle
                      #40
                      try z1
                      www.z1enterprises.com
                      91 kwaka kz1000p
                      Stock
                      ( Insert clever quote here )
                      • Axel
                        • May 2007
                        • 869
                        • Renfrew,Ontario
                        #41
                        Lines back
                        So it only cost me the return shipping to get the lines adjusted . They came today by courier .
                        XJ1100K
                        Avon rubber
                        MikesXS black coils
                        YICS Eliminator
                        • Axel
                          • May 2007
                          • 869
                          • Renfrew,Ontario
                          #42
                          Line leaks
                          What was that I said about hindsight . Lines are on . One leaks from the binding . So here we go again ...
                          XJ1100K
                          Avon rubber
                          MikesXS black coils
                          YICS Eliminator
                          • Geezer
                            • May 2003
                            • 2985
                            • Willamina, Oregon 97229
                            #43
                            Well you must have gotten the last 16mm master cylinder they had. They're out of them now as well as the high output coils.
                            Geezer
                            • Axel
                              • May 2007
                              • 869
                              • Renfrew,Ontario
                              #44
                              Wow
                              Yes ,they were out of stock when I checked on the site but when I emailed they said they had the one 16mm left so I grabbed it. It was actually on the handlebar and bled today until the line leaked .Now to ride this weekend ,all the old stuff has to go back on ...
                              XJ1100K
                              Avon rubber
                              MikesXS black coils
                              YICS Eliminator
                              • LoHo
                                • Sep 2002
                                • 1341
                                • Fresno, CA
                                #45
                                A few months ago I noticed that my rear brake had almost no stopping power. I usually use front brake, and add rear for emphasis, but using JUST rear had no effect. I had the stainless line from a set I purchased years ago, and decided it was time.
                                The rear master was full of rust and gunk. I cleaned it up and installed the braided steel line, then bled it until clear fluid came through without any air.
                                I went for a ride and was amazed that my regular pedal pressure could lock up the rear.
                                As it is now, my rear brake works great, and my front brakes work but don't lock up. Am I better off with the front not locking, as far as safety and avoiding skidding?
