I thought the brakes were ok until
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    #46
    Highside warning
    The way I understand things - Its better to not have your back wheel lock up but you should have the capability to lock up your front wheel . Threshhold braking teaches us how far we can really go with the front brake .
    Contrary to what we were taught in bike training way back in the day , the rear brake is not your friend at speed . It is only to be used as a complimentary thing . Great for slow speed manuvers but a producer of spills as when the rear wheel locks up at speed -the bike slides sideways and you guessed it - comes right over the top of you !!!
    Hundreds of articles on Motorcycle Safety/Dynamics and accident case studies
    Just a page I had in my favs . I'm sure to be less than complete in my answer so research to live !
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • Geezer
      • May 2003
      • 2985
      • Willamina, Oregon 97229
      #47
      I have stainless lines on the front of my 79 standard and the breaks don't lock up uncontrollably. I highly recommend these to everybody.
      Many years ago I had a Suzuki Water Buffalo and its dual front disks were mushy at best. I tried rebuilding the master cylinder, other master cylinders and hoses (I owned a bike salvage shop back then) and nothing worked. After reading an article on the subject in a bike rag, I had a place in Portland, Oregon custom make a set of stainless lines for me. I couldn't believe the difference and it was the best mod I did to that bike and there were many...
      Geezer
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        #48
        All but one
        My bike has all SS lines installed except for the right front . A new master and clutch perch now holds new mirrors . I hope to get the new line soon and really feel the power . It is stopping about the same as before now as I believe the rear/left front disc system needs more bleeding . BUT. I am in the wind for the weekend . A big thank you to my neighbourhood mech who came back to work at 7:00 - 10:00 to help me out at his shop .
        XJ1100K
        Avon rubber
        MikesXS black coils
        YICS Eliminator
        • Geezer
          • May 2003
          • 2985
          #49
          If that were my bike, I'd undo that weird linked brake system. I had a 76 Guzzi 850 that had that system and I hated it.
          You have the right master cylinder to power both front disks now all you have to do is plumb it up...
          Geezer
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            #50
            more lines leaking
            I now have at least one other line leaking . Just about ready to explode ...
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
            • olebiker
              • Aug 2007
              • 692
              • Kingston ON
              #51
              Crap Axel I would think about now you are ready to stick those lines up the suppliers butt. Wonder if you can get your money back?
              http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                #52
                Originally posted by olebiker
                ..stick those lines up the suppliers butt. Wonder if you can get your money back?
                Probably not, not after that..
                • Geezer
                  • May 2003
                  • 2985
                  #53
                  Is it the lines or the banjo fittings? If it's leaking at the banjos, then either replace the copper washers or anneal them.
                  Geezer
                  • planedick
                    • Mar 2005
                    • 2068
                    • Yorba Linda, California
                    #54
                    Hard turns
                    The CHP teaches their riders how to make a turn with the bars turned all the way to the stop. Put the steering against the stop, put about 2000 rpm on, lift the feet to the pegs and slip the clutch and use the rear brake to control the lean and speed. A little practice in a parking lot and you will find it easy.
                    Drilled airbox
                    Tkat fork brace
                    Hardly mufflers
                    late model carbs
                    Newer style fuses
                    Oil pressure guage
                    Custom security system
                    Stainless braid brake lines
                    • Axel
                      • May 2007
                      • 869
                      • Renfrew,Ontario
                      #55
                      leak
                      The lines are leaking from the crimp section .Looks like shrink wrap over the top of the connection and its leaking out of that .
                      This is a sample :
                      XJ1100K
                      Avon rubber
                      MikesXS black coils
                      YICS Eliminator
                      • Geezer
                        • May 2003
                        • 2985
                        #56
                        Man that sucks. I would send them all back and ask for a refund. The local Harley shop in your area should have what you need on the shelf.
                        Geezer
                        • olebiker
                          • Aug 2007
                          • 692
                          • Kingston ON
                          #57
                          Axel if I remember right you are kinda out in the woods. If I can check at a local dealer for you let me know.
                          Carl
                          • xsilerating
                            • Dec 2006
                            • 430
                            • Eastern Ontario, Canada
                            #58
                            Hey Axel;
                            That's the strangest looking set-up I've ever seen.
                            Refund... yes!
                            Buy elsewhere... yes again!
                            1980 XS11 LG (Diablo)
                            1980 XS11 G (Bagger)
                            1978 XS11 G (White Knight)
                            1978 XS11 G (Skeleton)
                            2016 SS (S.S. Flyer)
                            • Axel
                              • May 2007
                              • 869
                              • Renfrew,Ontario
                              #59
                              SH1T HAPPENS for a Reason ?
                              Still waiting for a responce from the supplier . Even with the old rubber line on the right/font disc , I find the barke lever is very hard and requires extra force to operate . Seeing I may get yet another chance to order lines I am considering the upgrade to operate both front discs from this 16mm master to get more travel at the lever .
                              XJ1100K
                              Avon rubber
                              MikesXS black coils
                              YICS Eliminator
                              • strom
                                • 1577
                                • Slovenia, EU
                                #60
                                Leaks are bad mkay?
                                A friend went off the track at over 120 mph coz of that. Thats why I prefer to do my own work on the bike, especially the brakes. If they get me killed at least its gonna be my fault.
                                Luckily for my friend he was on a track and he was OK.
                                I wonder if a guzzi california front end could go on XS11.
                                It has 18" wheel, should be long enuff and best: 2x 320mm brembo oro series rotors and 4 piston calipers. Now THAT can STOP you (almost over the handlebars on my test ride).
                                LP
