auto cancel
  • XJOK2PLAY
    • 2099
    • Skiatook, Ok.
    #61
    From what I understand, you have to push DOWN on the switch to cancel the XJ signals. Not IN like the XS.
    Danged if you ain't right! Thanks Cbug!
    So... the answer is.... my auto canceller's work perfect... LOL
    2011 Kaw Concours 14 ABS
      I tried to test the double-tap on the signals while I was out riding today and it doesn't seem to bypass the auto-cancel. If anything, it just reset the timer.
      Where're those Mythbuster guys!
      • CatatonicBug
        • 6117
        • Clinton, UT
        #63
        I think that's all it does. I think I'd rather it NOT bypass it, because I have become accustomed to hitting the switch a second time if I feel it might cancel on me. I'd hate for that to then cause it to continue as I drive off down the road.
          That's why I (hopefully not just me!) was checking it out. I heard wrong and that's fine with me. It might have worked that way on everyone else's bike but mine was broken.
          • Hmar
            • Jun 2011
            • 100
            • Springfield. MA
            #65
            Nope
            Actually, sometimes, but only the left one, and only sometimes. Pressing in works for the left signal to cancel, and for the right, I need to press slighty left on the switch, and then press in. It passes MA inspection that way, so it works for me.
            1981 XS 11 special
            red
            40,000 miles
              The little contacts and/or the centering spring in the handlebar switch might be bent or dirty if it does that. It's almost a toss up between just letting it be or taking apart the switch and possibly breaking the old solder joints then having to go through the entire assembly to get it to work again.
              FWIW the one on my XS is about due for the full treatment again but I don't have to worry about passing inspection.
              • Hmar
                • Jun 2011
                • 100
                • Springfield. MA
                #67
                Honestly, since it passes inspection and gets me where I need to go safely, the flasher is somewhere at the bottom of my priority list, right below getting rid of those little bullet hole stickers that the PO put on the tank. By the time I get around to fixing it, I'll be so used to the little quirks it has that never be able to use one that works "right"
                1981 XS 11 special
                red
                40,000 miles
                • blkryno
                  • Jun 2007
                  • 158
                  • Minnesota, USA
                  #68
                  On my 81 SH the blinker would not even stay on when I first got it back on the road but after spraying the switch with some contact cleaner it works fine. Haven't checked it on the 79 SF yet.
                  blkryno
                  81 11 SH (83 Venture cct, Tkat fork brace on )
                  79 11 SF (83 Venture cct on the shelf for it.)
                  Semper Fi
                  Loud Pipes
                  Draw Cops
                  • Bellerophon
                    • Jul 2011
                    • 103
                    • Meridian, Idaho
                    #69
                    Yep, it works great. What I want to know is why Yamaha could provide it on my 79 XS, but my 08 FJR doesn't have it.
                    2016 Yamaha FJR1300A
                    2007 Kawasaki KLR650A
                    1979 Yamaha XS1100SF
                    1971 Kawasaki F6 125
                    • JLeeper
                      • May 2011
                      • 11
                      • Hyak, WASHINGTON
                      #70
                      My auto-cancel worked great until after I swapped out the speedo to the 1979 160mph one. Anyone know if I can make it work with the 160 speedo?
                      1980 XS1100
                      1997 Ural Sportsman (2-wheel drive)
                      1975 Kawasaki F7-175 Enduro
                      • MrOzz
                        • Aug 2008
                        • 782
                        • Massachusetts
                        #71
                        I bet the reed switch in the speedo is no good. You can replace it. I had to do the same with mine. Check out this thread http://www.xs11.com/forum/showthread.php?t=33221 scroll to the bottom and you will see the part # I used.
                        1980 XS 1100SG
                        Dyna 3 Ohm Hi Output Coils
                        Pod Filters
                        DynoJet Kit
                        T.C.'s Fuse Block
                        V-Max Auto CCT
                        • Jeff Pattee
                          • Sep 2010
                          • 21
                          • Eugene, Oregon
                          #72
                          auto cancel
                          Yep, mine works now. It didn't when I first got the bike a couple of years ago. But then I started going thru the ele. system looking for problem areas, I found that a couple of wires to the unit had some ele. tape on them. I removed the tape and found burnt corroded splices, no solder, just twisted together, and to add insult to that, those two wires were transposed in the plug......I figured the unit was a gonner, but after I got it straightened around and fixed properly, Yahoo !!!!......been working fine every since
                          "Pop.pa Pipes"
                          Tends to overthink even the smallest little glitches
                          1978 XS1100
                          '79 Special Tank
                          210 air pilots, 137.5 Mains
                          4 into 2 Jardines
                          1st over, standard bore
                          1978 Intake cam
                          Later style exhaust cam
                          • Joab
                            • Aug 2010
                            • 472
                            • Ozark, Alabama
                            #73
                            Mine does not work, but it looks like the controls are getting gummed up to the point the switch sticks in the right position, and I have to pop it back to center now anyway. Just add it to the growing list...
                            Joab
                            "If nothing else, it will be interesting..."
                            ______________________________________________
                            1979 XS1100SF
                            1972 XS2 650
                            Ozark, Alabama
                              • 3206
                              Mine works fine, however, as has been said before in this thread, I push-cancel it 99% of the time out of good riding habits so the signal doesn't continue to flash and mislead a cage driver.
                              Self-cancelling turn signals, IMO, are not a regular use feature, per se, but to cover ourselves when we do forget to turn off the signal.
                              ZRX1200
                              • MPittma100
                                • Aug 2011
                                • 2359
                                Self Cancel
                                Both of my bikes work. They are stock. Had a problem when I first got the SF. Signals would come on and not blink. Took the OE flasher apart, filed the contact points, put it back together and they went right to work. That was a year ago.
                                MP
                                1981 XS1100H Venturer
                                K&N Air Filter
                                ACCT
                                Custom Paint by Deitz
                                Geezer Rectifier/Regulator
                                Stebel Nautilus Horn
                                EBC Front Rotors
                                Limie Accent Moves On In 2015
                                Mike
