latest mpg
  • shutchis
    • Oct 2004
    • 191
    • Deer Park, TX
    #76
    I’m getting 36 MPG with Houston's 10% alcohol fuel; 41 MPG with real gas at 65 MPH. However, I'm running my '82 XJ1100 with a fully electronic fuel injection (EFI) system. The ignition is a GM DIS unit off a Chevy Cavalier. Note: The spark system will hurt you. I know because it bit me one day when I pulled a spark plug lead with the engine running.
    My best mileage is 47 MPG at 55 MPH, 98 octane; but I was probably running a little lean.
    I installed a wide band O2 sensor last fall, but haven’t had a chance to retune the EFI controller, so I might get a little better mileage with a day of tweaking. At the current gas prices, I should make this a priority. It’s still better than driving the car at 22 MPG. My MC is configured with a full Slipstreamer windshield and an XS750 rear end differential mod, with after market pipes. Stan
    '80 XS1100LG Midnight Special
    Looks like an '82 Maxim, Fuel Injected
    '82 XJ1100J, Fuel Injected
    Stan Hutchison
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      #77
      81 project suggestion
      I will put that on the to-do list...looks like a good idea
      MDRNF
      79F.....Not Stock
      • FSCGunslinger
        • 200
        • Hedgesville, WV
        #78
        Re: heres some other happy customers
        And this'll work on the XJ's? Is it needed on them as well?
        "I said I never had much use for [a pistol], never said I didn't know how to use one."
        '82 Maxim XJ1100J (Maroon) - "Organ Donor" - Parts bike
        '82 Maxim XJ1100J (Black) - "Outrider" - Dynojet Stage 1 kit, Kerker 4-1 exhaust, AGM battery, Mikes XS coils, small inline fuel filters, Dunlopp Elite-3 tires
        '06 Star Warrior (Custom Gadsden Flag Theme) - "ΜΟΛΩΝ ΛΑΒΕ" - Sissy bar w/ luggage rack, 4" risers, braided stainless steel cables and brake line; Mods on deck: new exhaust, new seat
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          #79
          xj's
          if the xj does NOT have a balast resistor, and the coils are 3 ohm, then yes, the Vf1000 coils will work....So will the ZRX coils or the Dyna GREEN coils (3 ohm vs 1.5ohm red Dyna's) A lot of the late 90's Kawasaki coils are 3-ohm and have replaceable wire connections as well....chop
          MDRNF
          79F.....Not Stock
          • FSCGunslinger
            • 200
            • Hedgesville, WV
            #80
            Re: xj's
            Ok, so how do I find that out?
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              #81
              wait
              wait for an XJ owner to chime in....
              MDRNF
              79F.....Not Stock
              • shutchis
                • Oct 2004
                • 191
                • Deer Park, TX
                #82
                The XJ does NOT have a ballast resistor. I ran with the green Dyna coils for years; which are 3 ohm.
                Stan Hutchison
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  #83
                  your answer
                  I thought so. This 81 motor and wiring harness I have don't have the resistor either, I will slap these coils on it...They read 2.88 ohms...you could put them on the earlier motors without the resistors...someone was talking about this in an earlier thread
                  MDRNF
                  79F.....Not Stock
                  • 03mach1
                    • 114
                    • Cuba, NY
                    #84
                    2nd tank, 27.9 MPG approx. Getting a bit better, mostly highway on this one. It has 4 into 1 Kerker but stock air box and not sure if tuned correctly. Supposedly the PO re-jetted when they put the exhaust on.
                    Plugs look good. Running Seafoam thru it to try and clear the low end bog. Seems to be getting a bit cleaner...
                    More riding tomorrow and Sat. Maybe get a betting rating.
                    Dave
                    • BrianB
                      • 362
                      • Idaho
                      #85
                      I finally got around to finding out my Mileage on my 80 special. It is all stock except for the 4 into 1 exhaust. Last two tanks I averaged between 36 and 38 MPG. I usually run around at about 4000 RPM as well and love quick accelerations so I could possibly get better.
                      1980 XS Eleven Special
                      • Hammerhead1st
                        XStremely XSive(Deceased)
                        • Jul 2007
                        • 330
                        • Lawrencvile, GA
                        #86
                        At last check, the Ratster was filled from half and measured by the trip scale. Average mpg in town is around 51. By in town, I mean the open road 45mph stretches around here. Not inside Atlanta. Havent looked at hwy here but on the way down it wasnt too great. Apparently, lightening the load had something to do with that?
                        "Rat Rod"
                        79 XS1100 Standard
                        87 VMAX cans
                        Cheap Japanese Tires
                        Cobalt Blue Rattle Can Paint
                        Custom Lighting on a Budget
                        Perry Center Fire Department
                        Perry Emergency Ambulance
                        "If we don't do it, who will?"
                        Some people have one of those days, I have one of those lives...
                        • Fddlefoot
                          • Nov 2006
                          • 71
                          • Arvada, CO
                          #87
                          Riding
                          Well mileage depends on who I'm riding with and where when commuting to and from work about 16 each way 10 of which highway get around 30 but if out riding with ball and chain she keeps my speed down and mpg up around 34-35. guess who is the responsible one is??
                          " That glass isn't half empty it has a hole in it "
                          79 SF set to cruise
                          80special work in progress
                          and now 78 needs work
                          • 03mach1
                            • 114
                            • Cuba, NY
                            #88
                            Couple of trips this past holiday weekend.
                            It;s Getting better and I think the carbs are getting cleaned out.
                            Friday - 101 Miles @ 3.3 gallons = 30.6 (Rinding Double)
                            Sat. - 88 Miles @ 2.7 gallons = 32.5 MPG (Single, mostly highway)
                            Dave
                            • Wildkat
                              XS Special Gurette
                              • Apr 2004
                              • 3416
                              • Location, Location
                              #89
                              Worst gas mileage yet...
                              0 mpg on our recent Talihina trip...
                              okay... so my odometer and trip. stopped working...
                              Mountain riding, twisties and some highway... averaged about 38 mpg... a little less than that running just the twisties...
                              81 SH Something Special
                              79 SF MEAUQABEAUXS
                              81SH Nor'eas tah (Old Red)
                              80 LG Black Magic
                              78 E Standard Practice
                              James 3:17
                              “Alis Volat Propriis”
                              Yamaha XS 1100 Classic
                              For those on FB
                              • psycoreefer
                                • Feb 2008
                                • 1557
                                • Minden, NV
                                #90
                                39.955 over the long weekend. That was the average over two tanks I went through cruising around with SWMBO. Bike is mostly stock but I think its running a bit lean due to 4 to 2 exhaust. 1up mostly 2 lane roads 50 - 65ish. I have to go slow when shes around cuz her honda shadow just can't keep up if I hammer on it.
                                1979 xs1100 Special -
                                My Bike:
                                [link is broken]
