Bike Jack
+ More Options
Posts
  • XSrunner
    • Feb 2008
    • 97
    • Batemans Bay AUSTRALIA
    Bike Jack
    HI EVERYONE ..I WANT TO BUY A BIKE JACK TO USE AT HOME BUT THE PIPES ON MY BIKE ARE UNDER THE FRAME .HAS ANYONE MADE A MOD TO GO AROUND THE PIPES I DON'T WANT TO REMOVE THEM EVERY TIME I WANT TO USE THE JACK THANKS.
    JOHN'O
    Xs1100E 1978
    American Import Cruiser
  • HobbyMan
    MeatHead Idiot "GURU"
    • Jul 2006
    • 1801
    • Colleyville, TX
    What are you working on? If your doing front end stuff, put a car stand in front of the engine where the frame tube runs across. That holds the front end up and the rear wheel close to the ground. If you want the whole thing up, I just use a standard motorcycle jack to lift the bike and then I set it down on 3 car stands. Two in the back on each side of the frame and one in front of the engine. What kind of pipes do you have?
    Acta Non Verba
      ARE YOU JUST TRYING TO GET THE TIRES OFF THE GROUND, OR TRYING TO GET IT UP HIGH ENOUGH TO BE AT A MORE WORKABLE LEVEL?
      • XSrunner
        • Feb 2008
        • 97
        i have 4 into 1 pipes and they run underneath and along the frame (lower than the frame so a bike jack won't sit flat. i have panniers on the back and i want to work on the rear (fill final drive spline with grease) and i don't want to take them off everytime i want to take the rear wheel off. there's not enough hight to drop wheel low enough to get past the rear frame on panniers. (
        JOHN'O
        Xs1100E 1978
        • malber
          • Sep 2006
          • 568
          • Belmont, NH
          No centerstand?
          1981 XS1100SH
          • 79XS11F
            • Jul 2006
            • 3563
            • Ottawa, Ont. Canada
            Your going to have to make yourself a rack that will sit on the jacks flat pads that has uprights that contact the frame before the pipes contact the jack or the rack. If your bike jack is the same as mine even with the pipes removed it's a real tight fit between the side stand mount point and the main stand mount point to use the jack.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • Dsxs11
              • Jun 2007
              • 240
              • Millington, Michigan
              I gave mine away. It was the most worthless POS I've ever owned. I bought a bike lift instead. I'm not trying to talk you out of it, But you may not get exactly what you want with a jack. It may be a bigger hassle then taking the bags off.
              I hate signatures. Too many cars and Bikes to list here.
              • malber
                • Sep 2006
                • 568
                • Belmont, NH
                Oh, duh. I see the centerstand now. I agree: probably less expense and grief to just take the bags off. This type of service is something you'll likely only need to do every 20k miles or so.
                1981 XS1100SH
                • planedick
                  • Mar 2005
                  • 2068
                  • Yorba Linda, California
                  Bag mounts
                  My home built custom pannier mounts will swivle up just like the fender and luggage rack after taking out just one bolt allowing the removal of the rear wheel when it's on the center stand.
                  Drilled airbox
                  Tkat fork brace
                  Hardly mufflers
                  late model carbs
                  Newer style fuses
                  Oil pressure guage
                  Custom security system
                  Stainless braid brake lines
                  • XSrunner
                    • Feb 2008
                    • 97
                    thanks for the answers ,I suppose i was just trying to be lazy, i'll take the bags off anyway it will be interesting to see what it looks like without them.
                    JOHN'O
                    Xs1100E 1978
                      XSrunner, While on the center-stand remove seat and you'll see where rear fender is hinged to come up after removing a bolt on each side. Also remove center section of wrap-around bumper tubing.
