79 XS1100 Standard Questions
  • 79 XS1100 Standard Questions
    Did the 1979 XS1100 Standard come with a rectangular headlight and 17 inch rear wheel?
    Paul
    1983 XJ1100 Maxim
    1980 XS1100 Special
    I'm not a motorcycle mechanic but I play one on the internet.
    Yes
    That's right...
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
      Re: Yes
      Originally posted by planedick
      That's right...
      Hmmmmmmmmmm.................................I was afraid you'd say that!
      Paul
      1983 XJ1100 Maxim
      1980 XS1100 Special
        Why
        Why do you say "I was afraid you'd say that"?
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
          Re: Why
          I just purchased a 1979 XS1100 standard. I was sure the headlight was the wrong one but it wasn't until I removed the hard saddle bags that I discovered she was sporting a 16" wheel, not 17'.
          Despite the blown motor, the rest ain't bad, including the 2 big tote boxes full of spare parts.
          Paul
          1983 XJ1100 Maxim
          1980 XS1100 Special
            HEY Giant,
            Check the VIN # on the frame, and the engine to make sure they match, and then check them with the #'s in the MISC section for determining which year/model you have. The 16 wheel should be for Specials, but folks have mixed and matched parts for a variety of reasons!?
              What about the front axle and tank, Paul? A standard's axle is directly in line and underneath the fork tubes, ona a special is is on the front side of the lower legs. A standard tank is boxier, with a large, recesses rectangular filler cap. The Special cap sits proud of the tank, and is a narrower, elongated shape. MAybe you've got a Special?
              Ken Talbot
                Thanks Ken and T.C.
                No i'ts definitly a standard. The other giveaway was the slots in the rear brake rotor. Vin # is 2H7-110XXX. The front axel is as you said it should be too, and no slots in the rotors.
                I think this bike may have a lot of history!
                And I'm ok with that.
                Paul
                Paul
                1983 XJ1100 Maxim
                1980 XS1100 Special
                  We'll get you fixed up.
                    Do you offer a payment plan?
                    Paul
                    1983 XJ1100 Maxim
                    1980 XS1100 Special
                      Hey Paul, where did you pick that one up from?
                      Ron
                      1980 XS11 LG (Diablo)
                      1980 XS11 G (Bagger)
                      1978 XS11 G (White Knight)
                      1978 XS11 G (Skeleton)
                      2016 SS (S.S. Flyer)
                        I sent you an e-mail at work.
                        • #13
                          Ron
                          Local paper under moving sale! Not sure yet whether I'm the lucky one or the seller was!
                          Paul
                          1983 XJ1100 Maxim
                          1980 XS1100 Special
                          • #14
                            Thanks, I'll check it on Tuesday.
                            Paul
                            1983 XJ1100 Maxim
                            1980 XS1100 Special
                            • #15
                              " Despite the blown motor "
                              Hi Paul,
                              so how "blown" is the motor?
                              One assumes it don't run but is there just a nasty noise when you crank it or is there a big hole in the crankcase with a broken connecting rod poking out of it?
                              And don't worry about mix'n'match parts because Yamaparts swap like Lego so don't think of your new machine as a dog's breakfast, it's unique is all.
