79 XS1100 Standard Questions
  • blue giant
    • Aug 2007
    • 880
    • Ontario, Canada
    Did the 1979 XS1100 Standard come with a rectangular headlight and 17 inch rear wheel?
    Paul
    1983 XJ1100 Maxim
    1980 XS1100 Special
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    Yes
    That's right...
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    • blue giant
      • Aug 2007
      • 880
      • Ontario, Canada
      Re: Yes
      Originally posted by planedick
      That's right...
      Hmmmmmmmmmm.................................I was afraid you'd say that!
      Paul
      1983 XJ1100 Maxim
      1980 XS1100 Special
      • planedick
        • Mar 2005
        • 2068
        Why
        Why do you say "I was afraid you'd say that"?
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        • blue giant
          • Aug 2007
          • 880
          • Ontario, Canada
          Re: Why
          I just purchased a 1979 XS1100 standard. I was sure the headlight was the wrong one but it wasn't until I removed the hard saddle bags that I discovered she was sporting a 16" wheel, not 17'.
          Despite the blown motor, the rest ain't bad, including the 2 big tote boxes full of spare parts.
          Paul
          1983 XJ1100 Maxim
          1980 XS1100 Special
            HEY Giant,
            Check the VIN # on the frame, and the engine to make sure they match, and then check them with the #'s in the MISC section for determining which year/model you have. The 16 wheel should be for Specials, but folks have mixed and matched parts for a variety of reasons!?
              What about the front axle and tank, Paul? A standard's axle is directly in line and underneath the fork tubes, ona a special is is on the front side of the lower legs. A standard tank is boxier, with a large, recesses rectangular filler cap. The Special cap sits proud of the tank, and is a narrower, elongated shape. MAybe you've got a Special?
              • blue giant
                • Aug 2007
                • 880
                • Ontario, Canada
                Thanks Ken and T.C.
                No i'ts definitly a standard. The other giveaway was the slots in the rear brake rotor. Vin # is 2H7-110XXX. The front axel is as you said it should be too, and no slots in the rotors.
                I think this bike may have a lot of history!
                And I'm ok with that.
                Paul
                Paul
                1983 XJ1100 Maxim
                1980 XS1100 Special
                • Meatloaf
                  • Jun 2006
                  • 116
                  We'll get you fixed up.
                  • blue giant
                    • Aug 2007
                    • 880
                    • Ontario, Canada
                    Do you offer a payment plan?
                    Paul
                    1983 XJ1100 Maxim
                    1980 XS1100 Special
                    • xsilerating
                      • Dec 2006
                      • 431
                      • Eastern Ontario, Canada
                      Hey Paul, where did you pick that one up from?
                      Ron
                      1980 XS11 LG (Diablo)
                      1980 XS11 G (Bagger)
                      1978 XS11 G (White Knight)
                      1978 XS11 G (Skeleton)
                      2016 SS (S.S. Flyer)
                      • Meatloaf
                        • Jun 2006
                        • 116
                        I sent you an e-mail at work.
                        • blue giant
                          • Aug 2007
                          • 880
                          • Ontario, Canada
                          Ron
                          Local paper under moving sale! Not sure yet whether I'm the lucky one or the seller was!
                          Paul
                          1983 XJ1100 Maxim
                          1980 XS1100 Special
                          • blue giant
                            • Aug 2007
                            • 880
                            • Ontario, Canada
                            Thanks, I'll check it on Tuesday.
                            Paul
                            1983 XJ1100 Maxim
                            1980 XS1100 Special
                              " Despite the blown motor "
                              Hi Paul,
                              so how "blown" is the motor?
                              One assumes it don't run but is there just a nasty noise when you crank it or is there a big hole in the crankcase with a broken connecting rod poking out of it?
                              And don't worry about mix'n'match parts because Yamaparts swap like Lego so don't think of your new machine as a dog's breakfast, it's unique is all.
