New member:TurboXS, super modded
  • Mathh
    • Nov 2006
    • 665
    • Beek, Netherlands
    Originally posted by pggg
    Mathh, what's the highest accurate speed that bike has done?
    With homemade taller gearing it has run over 300kph, long time ago. Stock gearing did 235 kph. Now I guess with the FJR parts it will do 265 kph.
    MV Agusta Brutale 910R '06.
    Yamaha MT-09 Tracer '15 grey.
    • Mathh
      • Nov 2006
      • 665
      • Beek, Netherlands
      Re: undeserving
      Originally posted by xschop
      One question, Is the driveshaft perfectly straight or did you have to offset it for the fat tire? Awesome Craftsmanship and welcome....chop
      Thanks! tire is absolutely straight behind the front wheel (and no, the front wheel is not offset).
      Here a pic of the start of the project. Notice the distance between U-joint and shaft in swingarm..
      Click image for larger version  Name:	dscn0364a.jpg Views:	0 Size:	79.8 KB ID:	876472
      Because of the different swingarm construction the left frame pivot point has been deleted as such and the frame has been modified to accept the new axle pivot point. A 3cm wide spacer was needed to get the middle drive gear inline with the shaft.
      Click image for larger version  Name:	alles 363.jpg Views:	0 Size:	113.7 KB ID:	876470
      Deleted stock swingarm pivot point ... now houses the speedo drive sensor..
      Two longer middle drive gear shafts... one lengthened by welding, one completely new one-off. Both 3cm longer than stock.
      Click image for larger version  Name:	alles 367.jpg Views:	0 Size:	114.6 KB ID:	876474
      • HobbyMan
        MeatHead Idiot "GURU"
        • Jul 2006
        • 1801
        • Colleyville, TX
        If you ever come over here, you must visit me first what a nice bike and welcome, finally.
        Acta Non Verba
        • chevy45412001
          • Mar 2003
          • 1412
          • Jacksonville Florida
          welcome
          first let me start out by saying DANG that bike is sic!!!!! very well crafted and tough as snot i bet.. anyway welcome aboard or a broad whichever.
          1982 XJ 1100
          • pggg
            • 1609
            • NZ
            Aaaa.... uummmm... yep 300 kph on an XS11 might just about be fast enough Hells teeth, you'd need to be tucked in low, 300kph on a naked bike, you wouldn't want to have long legs and arms...
            • BLUEJEEPLAB
              • Sep 2005
              • 703
              • Miami Valley, Ohio
              HOLY %&$#@!!! Awesome!!! Math, you are a Master!!! Simply having come up with the concept, let alone to realize it makes you somone special in our ranks. Can we automatically elevate Math to Guru status?
              Papa Gino
              79 and something XS 1100 Special "Battle Cruiser"
              78 XT 500 "Old Shaky"
              02 Kawasaki Concours "Connie"
              • Mathh
                • Nov 2006
                • 665
                • Beek, Netherlands
                Thanks a lot for the compliments. I'll post a couple of detailed pics for the real lovers.
                New lenghtened middle drive shaft (the one on the left)
                Click image for larger version  Name:	DSCN1828a.jpg Views:	2 Size:	51.4 KB ID:	876476
                Hydraulic clutch engagement. Just made a small adjustable adapter between the cylinder and clutch actuator to fill up the gap.
                Click image for larger version  Name:	DSCN2753aa.jpg Views:	2 Size:	106.6 KB ID:	876477
                Oil filter adapter plate with thermostat and cooler connections:
                Click image for larger version  Name:	DSCN2761aa.jpg Views:	2 Size:	104.7 KB ID:	876478
                • Mathh
                  • Nov 2006
                  • 665
                  • Beek, Netherlands
                  Kawasaki DFI set up slaughtered und put together again in the correct intake width:
                  Click image for larger version  Name:	DSCN2769aa.jpg Views:	0 Size:	159.1 KB ID:	876485
                  Computer Electromotiv:
                  Click image for larger version  Name:	DSCN2767aa.jpg Views:	0 Size:	110.6 KB ID:	876486
                  upper cable is for EFI Injection, lower for tacho drive
                  Click image for larger version  Name:	DSCN2752aa.jpg Views:	0 Size:	162.5 KB ID:	876487
                  Coils from Electromotiv:
                  Click image for larger version  Name:	DSCN2763aa.jpg Views:	0 Size:	118.5 KB ID:	876488
                  Lambda probe welded into the interlink pipe between turbo and muffler
                  • Mathh
                    • Nov 2006
                    • 665
                    • Beek, Netherlands
                    Honda SP-1 cockpit and RSR air/fuel gauge:
                    speedo drive by NPN-sensor (in the abandoned swingarm pivot housing) reading the number of teeth passing from the modified transmission gear pressed onto the U-joint..
                    fuel pump and filter:
                    • HobbyMan
                      • Jul 2006
                      • 1801
                      • Colleyville, TX
                      One word: WOW How long did it take you to get/make all of those parts?
                      Acta Non Verba
                      • Mathh
                        • Nov 2006
                        • 665
                        • Beek, Netherlands
                        Well...........since 1982. Then I bought it new and after 1500 km of running in I bolted on the kit from American Turbo Pak. The bike has been altered a number of times since. You can see its history at
                        www.xs1100.com under "projecten"
                        In total it has seen approx. 200.000 km now and a new change is on its way as I think the alternator and seat are too big and the Electromotive is good but as you call it: a dinosaur.
                        • mason79
                          • Mar 2006
                          • 1351
                          • los angeles, ca
                          i went thru your website a little, and in 92 you enlarged your gas tank, awesome!
                          i like the obessesion you'ver had since day one, definately a first rate engineer and designer!
                          History
                          85 Yamaha FJ 1100
                          79 yamaha xs1100f
                          03 honda cbr 600 f4
                          91 yamaha fzr 600
                          84 yamaha fj 1100
                          82 yamaha seca 750
                          87 yamaha fazer
                          86 yamaha maxim x
                          82 yamaha vision
                          78 yamaha rd 400
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            gotta ask
                            do you know what the final drive ratio is?
                            MDRNF
                            79F.....Not Stock
                            • Mathh
                              • Nov 2006
                              • 665
                              • Beek, Netherlands
                              Re: gotta ask
                              mmmmm, this is what I could find about the FJR1300 (5JW1-AG1):
                              "Primärübersetzung: 74/48 (1.563)
                              Sekundärübersetzung: 35/36 x 21/27 x 33/9 (2,773)
                              Getriebe abstufung:
                              1. Gang 43/17 (2,529)
                              2. Gang 39/22 (1,773)
                              3. Gang 31/23 (1,348)
                              4. Gang 28/26 (1,077)
                              5. Gang 26/28 (0,929)"
                              Now let me know what you are going to calculate?
                              • malber
                                • Sep 2006
                                • 568
                                • Belmont, NH
                                Welcome fellow new member. This is surely a very cool bike. But when the only stock item is the motor, at what point is it no longer an XS1100?
                                1981 XS1100SH
