Removing the forks cap on an air assisted damper
  • LoftCol
    • Jul 2025
    • 28
    • UK
    Does anyone have any tips on removing the fork cap on the air assisted forks. There is not much room to get a spanner to fit and apply pressure without it releasing and damaging the clocks. Thanks
    • 1881
    You need to tell everyone what you are working on. Year, model etc.. Why are you wanting to remove them? I looked at your handle in member list and you say you have an xs1100 se, so I am assuming you have a 78 standard model. Better to have the fork/forks off the bike to work on them. Your use of the term spanner indicates you are not located in the United States. When you take the fork caps off they are under a good bit of pressure because of the spring in there. When you loosen them it is best to keep a cloth and one hand on them as you unscrew the cap. Otherwise you will have to watch where it flies too.
    • LoftCol
      • Jul 2025
      • 28
      • UK
      Sorry, based in the UK, model is a 1979 SF import from the USA, but over the years and previous owners have modified it to a European look. I want to remove the fork caps so that I can change the oil. Air pressure has been released, and I will raise the front end from the floor. I want crack open the caps slightly before I raise it. Just after some tips on the correct tool to use. Thanks for the reply
        • 1749
        Raising the bike's front end will take most of the preload off the springs but not all. The air forks are much softer because they use air for pre-load. You can remove them with a larger Crescent wrench but re-installing them may prove to be difficult. Pushing down with your fingers and finding the threads can be tough. You need to be very strong and dexterous. Or just be safe and remove the forks to work on them.
ID:	886210 Click image for larger version
ID:	886211 Click image for larger version
        • LoftCol
          • Jul 2025
          • 28
          • UK
          Brilliant, not sure which type I have until I get them off, but looking at the photos the one on the right looks very similar to mine, I will follow advice and remove them. I have an adjustable "crescent" spanner that will fit . Really appreciate your help. Cheers
            • 1881
            The reason we advise to remove the forks to work on them is because it allows you more access to it. Depending on how long it's been since the oil was changed you might find that you need to clean the inside of the tube once you get all the internals out and it will also make the job of getting the fork cap back on more flexible. When I say flexible as Deebs stated it takes some pressure pushing down on it and turning it at the same time to get it to catch and hold enough to be able to then use the wrench. The threads are fine and you seriously don't want to cross thread it.
              • 2077
              I've found that this task is so much easier when the cap is held protected in a vise and fork tube in hand the feel for the threads is way better. Also alot easier than trying to hold the cap to overcome the spring pressure.
              • LoftCol
                • Jul 2025
                • 28
                • UK
                Thanks for the suggestions
