Wanted Kick start bracket
  • Janesy
    • Jan 2026
    • 4
    Wanted: Kick starter bracket etc to hold kick starter on to frame.’79 XS1100 Special
  • LoftCol
    • Jul 2025
    • 78
    • UK
    Hi, I can sketch the one I have if you want so that you can get one made if that helps
      This should help.
ID:	887199 Click image for larger version
ID:	887200 Click image for larger version
ID:	887201 Click image for larger version
      • Janesy
        • Jan 2026
        • 4
        Thank you for your response. I have the clip but I don’t have the end cover with the wing nut.
        • Janesy
          • Jan 2026
          • 4
          I have never attempted to locate the kickstart lever on the bike and CSMNL does not show how it is installed. Ill check utube and see if there is a video how to install it.
            Cover with nut.
              • 8904
              On your 79 Special, the small bracket that holds the part of the kickstarter where you place your foot should be already installed under the battery box on the left side of the bike. As for holding the other end of the lever to the frame on the right side of the bike, a metric bolt of the correct size and a washer could be used instead of that hard to find cap/wing nut assembly.
              • Janesy
                • Jan 2026
                • 4
                Thank you all for your information. I will get a bolt and washer that will do for now. Im still going to look for the bracket. I have had this bike for 42 years and it is in almost mint condition. The kick start lever situation only came up recently as i found the lever in a box of other stuff tat has been sitting for years!
