Been having a heck of a time rebuilding my rear master cylinder on my '79F. I suspect I may have scored the bore up too harshly while cleaning Have tried polishing with 1000/1500grit. With a new "All Balls" rebuild kit it's still leaking down to the dust seal and not bleeding well at all. If anyone in the US has a good rebuildable/usable spare, I'd be interested in buying!
WTB: rear master cylinder for XS1100F
gtem,
I have a couple of them on eBay. Still got a lot of parts to get rid of, so, most reasonable offers accepted. Even unreasonable offers considered.
rucksack.grunt on eBayBob's Bikes:
"Project XS11"
- 1 like
rucksack.grunt on eBayYamahas: 1979 XS1100F
Past Yamahas: 1978 XS1100E, 1976 XS500C
Originally posted by gtem View Post
Thanks Bob! I took a closer look at mine closer and finally identified the bit of pitting in the bore that was likely causing me grief. I skimmed some JB weld on and will try to polish it up again and see if I can sort it out. If not I will be making you an offer on one of yours!
This gives you a lot more leeway on searching for a replacement. By the way Bob's are more of a safe bet, knowing how meticulous he is with his projects, then others might be.
Just my two cents here but I would never trust my brakes to JB Weld. On top of that parts are getting scarcer. Your call though.2 - 80 LGs bought one new
- 2 likes
Question, did you bench bleed the M/C before installing, otherwise you could have the problem you are describing. The piston can be pushed in too far disrupting the rubber seals causing a leak from the back side. Also it is impossible to bleed even with a vacuum pump.2H7 (79) owned since '89
- 1 like
Mine will not bleed with the caliper mounted since that short piece of rubber hose between the hard line and caliper sits higher than the bleeder. Had to disconnect the caliper and raise it up to get it done.1980 XS1100G
I identify as a man but according to the label on a package of Stauffers Baked Lasagne I'm actually a family of four!
- 1 like
Very interesting, yes I did have some issues bleeding as what you guys describe. But the telltale symptom I noticed with the M/C just on the bench was that it would pull vacuum on the dust seal, implying the bottom "rear" seal wasn't sealing well. I'm going to see how this bore polishes up and seals better. That's an interesting comment too that it's possible to push that piston in too far when bench bleeding and contributing to my "vacuum on the dust seal" observation.Yamahas: 1979 XS1100F
Originally posted by gtem View PostVery interesting, yes I did have some issues bleeding as what you guys describe. But the telltale symptom I noticed with the M/C just on the bench was that it would pull vacuum on the dust seal, implying the bottom "rear" seal wasn't sealing well. I'm going to see how this bore polishes up and seals better. That's an interesting comment too that it's possible to push that piston in too far when bench bleeding and contributing to my "vacuum on the dust seal" observation.2 - 80 LGs bought one new
This is the tool to use to properly hone master cylinders. Clean the bore afterwards with hot soap and water to get rid of the grit. Leftover grit may be your issue with sealing. it's difficult to clean a bore properly after a hone. If it's not done right you will have the type of issues you are experiencing.
https://dealer.klsupply.com/general-...e-320-grit.asp
gtem,
I just sent you a pm,
BobBob's Bikes:
"Project XS11"
