Spin on oil filter adapters
    • 9980
    Originally posted by Bax
    BA80 Greg, preemptive apologies if it does not fit as TC suspects.
    ---Bax
    If there's any way it'll work I'll find it. I have one of TC's on Ol' Okie so there's that. I have something to pattern by.
    • Bax
      • 344
      • Merrimack, NH
      Going by TCs posted dimension, an OEM cooler insert in the stack may resolve the clearance issue.
      ---Bax
        • 9980
        I have 2 of those. We'll see.
          Hey Bax, What you say makes sense, I think I remember seeing a plate like this attached to the bottom of an OIL cooler type plate, this would allow it to be much thinner just needed to have clearance for the custom NUT/BOLT/threaded pipe combination that I've seen made for the cooler plates, it doesn't stick out that far from the surface of the cooler plate. BTW, if you're wanting to put a cooler/SOFA type plate on yours, I've got the diagrams, measurements that I used to make both my SOFA and SOFCA and could send them to you if you like.
          Hey Mathh, I went ahead found your email addy with my ADMIN access, and sent you a copy of the diagrams/descriptions of measurements and how I machined them, hopefully you can use them, and hopefully your email addy on the site is still accurate/correct. IF you don't receive them, first check your junk folder because it will be coming from Hotmail.com and many email servers set those unsolicited emails a JUNK/SPAM. Next, if you still don't find it, then drop me an email with your current address.
          • Bax
            • 344
            • Merrimack, NH
            TopCatGr58 Hey TC, appreciate the offer, I won't turn down the measure drawings. It would definitely help me by not having to drop the filter to get the dimensions I'd need to make up the adapter.
            --Bax
            • Mathh
              • Nov 2006
              • 683
              • Beek, Netherlands
              Hi TC! Thanks for the drawings, just ordered some aluminum to get started ...
              MV Agusta Brutale 910R '06.
              Yamaha MT-09 Tracer '15 grey.
                • 9980
                Bump...........................
                  • 9980
                  Got this one from Bax. Fits fine with the oil cooler plate on there.
