STANDARD fork air cap/valve
  • Dbshea
    • Mar 2016
    • 133
    • Muskego, WI.
    Need to buy!
    Disassembled a set of venturer forks in prep for new seals. One cap looks to have taken some damage in a previous life.
    Special caps will NOT fit, special valves will NOT fit (however, if you need either of those I have plenty!)
    Let me know!
    Last edited by Dbshea; 07-28-2016, 01:19 PM. Reason: Clarify buying, not selling. Mods, feel free to edit title
    79 F
    Easily fixable........then I'd suggest you give Andreas a call at his listed number where he lists parts available. He may likely have some extra air-chuck valves for the Standard forks.
    • Dbshea
      • Mar 2016
      • 133
      • Muskego, WI.
      I think the cap itself is salvageable. Might be a little ugly, but this bike is no show stopper.
      I am thinking the easiest route will be to build a balance kit and just plumb in a T. Do you by chance know the thread of that valve body? Trial and error will probably be my friend...
      Also motorman, have you been inside your H forks? These came off an H but the springs are not progressive, and are actually just slightly longer than stock spec. Was a bit surprised by that.
      79 F
        Ddshea, gettin' way to old to even fit in them. Pulled them some 5-6yrs. ago, had them professionally taken completely apart, cleaned, dryed and put back together with 15w Silkolene and new seals. I also quit using any air in forks.
        As for the springs in yours............who knows which PO had them apart previously.
          I always thought they were 1/4" npt threads with a schrader valve on top. Might be wrong though I guess.
          • Dbshea
            • Mar 2016
            • 133
            • Muskego, WI.
            http://m.ebay.com/sch/i.html?_nkw=1%...schrader+valve
            That may be the case for a special? These caps are thread m10x1.25 and I'm playing hell trying to find a suitable replacement. Might end up getting creative.
            79 F
              • 9980
              Let me look and see what I have Dan. I think there's a set of Standard air forks out in the pile-o-parts.
              • Bigfoot
                XS-XJ GURU
                • Sep 2005
                • 1422
                • Kansas City, Missouri
                Here is how I have mine done, courtesy of mindwebs and Dragon tamer.
                Harry
                '79 Standard
                '82 XJ1100
                '84 FJ1100
                Acta Non Verba
                  • 9980
                  check your PMs Dan
                  • Dbshea
                    • Mar 2016
                    • 133
                    • Muskego, WI.
                    Thanks for all the input guys. I managed to salvage the set I have by tapping the broken valve seat to accept the special valv (m8x1.0 if any stumbled upon this)
                    We'll see if she holds air and move forward from there.
                    79 F
