I am in dire need of a TCI unit for my XJ.
TCI unit kaput
Re: TCI unit kaput
Your problem might be a simple as a cold solder joint that you can fix in about two minutes with a small soldering iron.Ken Talbot
That TCI will not swap to a stock XJ. It is for an XS, '78-'80. '81 and up used a TCI that has advance built into the box and the XJ also added a vacuum actuated boost sensor connected to the TCI.
This TCI will run the engine, but it will run poorly.
Jacket, have your TCI's been tested and how much $$ do you want for one?Last edited by randy; 08-21-2008, 06:17 PM.
