TCI unit kaput
  • TCI unit kaput
    I am in dire need of a TCI unit for my XJ.
    TCI
    Do you still need one ?
    I have 5 left.
    jackjet
      Re: TCI unit kaput
      Before you jump off a bridge, or spend a whole lot of buck$ on a replacement, be sure to read over Randy's post here
      Your problem might be a simple as a cold solder joint that you can fix in about two minutes with a small soldering iron.
      Ken Talbot
        I have 5 left.
        XJ TCI is different from XS TCI's
        Having 5 good XJ ones be worth a few bucks.
        mro
          jackjet,
          do you still have the TCI's and are they for an xj or an xs. I could also use an xj tci.
          Harry
          '79 Standard
          '82 XJ1100
          '84 FJ1100
          Acta Non Verba
            This is what I have now.
            The S/N isTID14-01
            2H7-10
            Jack Williams
            Hesperia ,Ca.
            jackjet
              That TCI will not swap to a stock XJ. It is for an XS, '78-'80. '81 and up used a TCI that has advance built into the box and the XJ also added a vacuum actuated boost sensor connected to the TCI.
              This TCI will run the engine, but it will run poorly.
              Jacket, have your TCI's been tested and how much $$ do you want for one?
                TCI
                Hi Randy,
                they work perfectly and I only want $50.00 each.
                Jack Jet Williams
                Hesperia,Ca.
                jackjet
