Eliminate Sqeaky Brakes.
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    As part my rebuild I installed new EBS copper sintered brake pads on my G.
    After a while they started squeaking, no - more like squealing like pigs!!
    Every time I pulled up to a light, I got stares. And when riding with others.... the comments were always forthcoming.
    I sanded the rotors to no avail. So I tried a trick I used to employ on my VWs and Volvos.
    I removed the calipers and pads, sanded the rotors with 80 grit, and then I grooved the pads. I grooved the pads by putting them in a vice, lengthwise, then using a hacksaw I cut a perpendicular groove leaving aout 1/8" of backing. This creates two +/- 1.25" X 1.25" pads on the metal backing.
    I then applied some of that 'special' brakepad grease on the backs of the pads, re-installed them, and re-assembled the calipers.
    Haven't heard a squeak or squeal since.
    Hope this helps if you're experiencing the same issue.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    I had a similar issue on the front with some Vesrah semi-metallic pads and I did a similar thing except I cut a very shallow X across the pads. Squeal went away and I still have the pads installed (though most of the X is now worn away).
    Not sure why this worked other than guessing that it helped get some of the brake dust out from between the pad and rotor.
    Mike Giroir
    79 XS-1100 Special
