I have an XJ1100J Maxim and have done the following to the bike to lessen the vibration in the handle bars:
1. Rotated the motor mounts 180 Degrees in the front.
2. Filled the handle bar extensions with bird shot, no help, removed.
3. Replaced the upper motor mount bolt with a tempered one to take the 40 ft lb torque, PO had a mild steel all thread (3/8-NF)that stripped out.
When I get the bike running again will take to my shop and investigate using a Spectrum Analyzer to find predominate frequency and severity at 3000/3500 RPM, worst case
Have heard of other techniques to reduce the vibration but cannot find the threads, weights at ends of grips, size weight length etc.
I was thinking about a DYNAMIC ABSORBER but do not have enough info to determine the frequency, severity, angle of displacement, weight needed etc.
Would like to have the absorber inside the bar so I can use standard grips.
Any help in this endeavor from the group will be greatly appreciated
