penetrants
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    penetrants
    Does PB Blaster etc. wick upwards?
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    • 2094
    Yes, it's my go to for a penetrant. I have Kroil also but I believe PB works better. Some have reported a 50/50 mix of Acetone and Transmission fluid works well but I've never had any good results.
    • DeanR
      • Jan 2005
      • 1499
      • Finger Lakes NY
      PB Blaster has come to my rescue numerous times.
      This time is a little different problem. I can't loosen a stupid thin, flat nut (about 1 1/2 inch) that tightens down a bathroom sink drain. Doesn't help matters that I can barely get a wrench on the damn thing.
      A new drain is ready but can't get the old one loose and out.
Name:	sink drain.jpg
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
        • 2127
        Pretend it's the bottom race in your bike's steering stem. Cut it with a Dremel or die grinder?
          • 1981
          Cutting is a good idea. I would try heat from a heat gun or a small pin-point propane torch. The heat will help the PB Blast wick inside the threads. Use small, thin vice grips on that lock nut.
            • 802
            How many times have you sprayed penetrating oil on a bolt and watched it burn off when you apply heat? Recently came across this YouTube short using a crayon of all things that totally makes sense!
              • 2094
              Dean, If you can get a drill perpendicular to the drain tube, drill a hole through the flat side of the nut maybe 3/16 or 1/4 inch. Then a small cold chisel from the bottom up split the nut and Bobs your Uncle Basin wrench is the proper tool for this situation.
              • DeanR
                • Jan 2005
                • 1499
                • Finger Lakes NY
                I'll hit it with the PB a number of times over the next few days and see what happens.
                Another BIG part of this problem is the thickness of that nut. Tough to get a wrench on it securely. No clue why it was designed that way.
                If it still won't budge, seems like there are a number of choices to cut it. Hadn't thought of drilling though!
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
                  • 283
                  there is a plumbers drain wrench made for this,,,it has a flexible wrench clamp on a swivel Click image for larger version
                  available at home Depot or similar stores,,,Mike in S.DIego and Pa.
                  • DeanR
                    • Jan 2005
                    • 1499
                    • Finger Lakes NY
                    Successful. Took a drill to the side of the nut until it cracked.
                    Hole in the sink was a mess. yuk. Porcelain over, I think, cast iron?
                    Just have to get the trap plastics all lined up and connected (it's a bit tricky for some reason) and pick up some silicone tomorrow. Thanks for the advice everyone.
                    80 SG
                    81 SH in parts
                    99 ST1100
                    91 ST1100
                      • 7800
                      For future use try a 50/50 mixture of ATF and Acetone. It's what we used on the coast to keep rust at bay, and free bolts. Kroil works very well also, but at $15 a can the mixture is a LOT cheaper.
